Message 1 of 4
improve upload speed
is there any way to speed up the upload speed n? currantly 5mbs, ftc connection, sadly no full fiber here yet 😞
3 REPLIES 3
Message 2 of 4
Re: improve upload speed
can you enter either phone number or address and post results   https://www.broadbandchecker.btwholesale.com/#/ADSL
can you also post hub stats - hub manager advanced settings then technical log information
Message 3 of 4
here is the output ? ty for looking
Serial number,+091298+1901014580
Firmware version,v0.40.00.04147-BT (Fri Apr 14 12:04:31 2023)
Board version,R01
GUI version,1.79 12_06_2022
DSL uptime,0 days 13 Hours 48 Mins 23 Secs
Data rate,5.4 Mbps / 38.6 Mbps
Maximum Data rate,5.4 Mbps / 39.1 Mbps
Noise margin,6.1/6.1
Line attenuation,10.8/22.4
Signal attenuation,10.8/23.1
VLAN id,101
Upstream error control,Off
Downstream error control,Off
Data sent / received,2.1 GB Uploaded / 2.1 GB Downloaded
Broadband username,[email protected]
Public Wi-Fi,Active
2.4 GHz wireless network name,BT-98A2W3
2.4 GHz wireless channel,Smart (Channel6)
5 GHz wireless network name,BT-98A2W3
5 GHz wireless channel,Smart (Channel36)
Wireless Security,WPA2 (Recommanded)
Wireless mode,Mode 1
Firewall,On
MAC address,
Software variant,-
Boot loader, 0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 4 of 4
@Hamtwiggg
from looking at the hub stats you posted you are getting as good a connection as you can get with connection speed up/down at max attainable
