imran999
Newbie
Message 1 of 2
infinity 1 being upgraded to 2 speeds. Do i need to plug in my BT router in?
i am being upgraded to the faster speed overnight , do i need to plug in my original bt router in?
I'm currently using the bt modem and a netgear router.
1 REPLY 1
Message 2 of 2
Re: infinity 1 being upgraded to 2 speeds. Do i need to plug in my BT router in?
Just stay connected the way you are and connection should reset when upgrade happens
