scotta1980
Message 1 of 7
interleaving on my line
how can i tell if i have interleaving on my line i have been having problems with speed and my ping latency has went up from around 26ms to well over 50ms + at times i have tryed to resolve tis with bt but its like banging your head off the wall
my speeds were good was getting around  60 down and 10mbps up but i am lucky to get 50mbps this has happend overnight
i have diched the hh5 for a openreach modem and my disconecting problems have gone away but my speed has not recoverd and my ping is still high
my homehub 5 has been disconnecting allot could have tis caused my problems
can any of the mods look into this form me just want the problem resolved thanks
6 REPLIES 6
Message 2 of 7
Re: interleaving on my line
If your speed dropped because of the disconnects it will mean that DLM will have seen this as a fault and lowered your speed to try and maintain a stable connection.
If you leave things alone and switched on 24/7 and provided the disconnects have stopped DLM will slowly increase your speed. This can, but not necessarily will take two to three weeks to happen.
BT will not request a line reset until DLM has had a chance to do its job.
See link about DLM. It is for Plusnet but it is more or less the same for BT
http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
scotta1980
Message 3 of 7
i have done a speed test again an i have noticed that my ip profile it totaly diffrent again overnight lastnight it was 49.2mbps checked againg when i got up today was at 51.8mbps and now its 47.29mbps
Message 4 of 7
with 3 different profile in 24hrs that would suggest you have not solved the disconnections and they are still happening.  as long as they continue your connection will not recover
scotta1980
Message 5 of 7
thanks for your info i think i will have to just leave it for now and hope it improves over time i will keep the openreach modem connected not going back to hh5 thats was a joke using that
Distinguished Guru
Message 6 of 7
I think you probably have an underlying line fault which would need fixing before your Infinity improves. My HH5 seems fine on my fault-free line.
If not, I'll try again 🙂
astar27
Expert
Message 7 of 7
Can you post your modem stats please?
