techmate
Message 1 of 12
ip profile has dropped infinity 2
hi to all
im hoping that a mod can help me,i have infinity 2
up to last wk end i was getting speeds of 76m and ip profile was 77.47m
now my profile is showing 66.72m and my speed is 69.79m
last wk end there was an outage
i have spooken with india and to be honest i wish i hadnt,
i told the lady that i have been getting brilliant speeds for nearly a yr
well 3 wks short of a yr
she told me that my line cannot take it
as i said to her ive had brilliant speeds of 76m
for nearly a yr so my line can take it..its since the outage last wk end my ip profile has dropped
i am really hoping that someone here can help please
 regards tm
11 REPLIES 11
Message 2 of 12
Re: ip profile has dropped infinity 2
If you have had a problem on the line, the outage, this will probably have caused DLM (Dynamic Line Management) to have kicked in. This is an automated process that lowers your speed and profile to try and maintain a stable connection. Once the problem is removed or repaired, DLM will slowly raise the speed again. This can but not necessarily will, take two or three weeks. It is unlikely that BT will do anything until DLM has had a chance to do it job.
techmate
Message 3 of 12
its now 2 wks and my speed still has not returned
i think my line needs to be reset from the outage that wk
how can that be done as india is no help.
hoping someone can help
rg tm
Message 4 of 12
Use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
http://speedtest.btwholesale.com/
techmate
Message 5 of 12
this is/was my speed before the outage as in 1st post
_______________________
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download Speed
 76.63 Mbps
0 Mbps 77.29 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 76.63 Mbps
 For your connection, the acceptable range of speedsis  40 Mbps-77.29 Mbps .
 Additional Information:
 IP Profile for your line is - 77.29 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 15.06 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 15.06Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
__________________________________________________________________
todays sp test 17/4/14 @ 14.05
 Download Speed
 65.4 Mbps
0 Mbps 67.35 Mbps
 Download speedachieved during the test was - 65.4 Mbps
 For your connection, the acceptable range of speedsis  40 Mbps-67.35 Mbps .
 IP Profile for your line is - 67.35 Mbps
 Upload Speed
 13.86 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 13.86Mbps
___________________________________________________________________
i allways use bt wholesale also turn off antivirus,as that will give bad results
as you can see not as good as it used to be
rg tm
Message 6 of 12
Try ONE reset of the Homehub and then re-run the speed test to see if it's improved. If it hasn't improved you could try complaining to BT but I suspect that you wll be told that you are within your estimated speeds and that they won't do anything about it.
techmate
Message 7 of 12
many thanks for advise
i did a reset and no change still low
have also complained and india is a waist of time.
they didnt seem to understand i have had brill speeds for nearly a yr.
was told i am in the estimated speed
therefore bt shouldnt advertise on tv speeds of 79m.
or bring call centre back to uk,
many thanks for your assistance
rg tm,
very unhappy customer
Message 8 of 12
To be honest, unless you are a very heavy user with muliple downloads or lots of streaming devices at the same time I doubt you will notice the difference in what you had and what you have. It is still possible that DLM will improve the speed however it could be that what you now have is as good as it will get.
techmate
Message 9 of 12
i understand what you are saying ,
i dont do any of those only use 1 computer.
i cant understand why its so difficult to reset a line
as there outage caused my drop
rg tm
Distinguished Guru
Distinguished Guru
Message 10 of 12
I can't see BT doing anything as your speeds are still within range. It may increase over the next couple of weeks but BT won't want to intervene on an automatic system.
