andyhudson1979
Message 1 of 3
is SHINE affecting my connection?
I am on infinity 1 with 76 / 20 speeds (I am very close to the cabinet).
However my connection doesn't stay up for more than 5 days. Whilst this isn't a bad problem, it is annoying.
My hub 6 loses sync every 5 days at 9.42pm. Because this is a precise pattern this makes me think it is some sort of electrical interference. Does anyone agree? How can I confirm my suspicion?
My noise margin on my hub stats just before it went down
I have done a quiet line test with a corded phone, it was fine.
My hub currently has noise margin 15.4 dB / 20.1 dB (it is usually this at most times) but just after it re-connected it was about 15 / 17, so because of the difference to what it usually is, this makes me think it is a shine event.
Here is a copy and paste of the log (I filtered wan, ppp and tr69):
21:45:25, 14 Mar.
ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
21:45:24, 14 Mar.
:WAN: SENSING AUTO VDSL
21:45:24, 14 Mar.
ppp1:PPP: PPP INFO
21:45:23, 14 Mar.
ppp:PPP: IPCP_NAK
21:45:23, 14 Mar.
ppp:PPP: CHAP_SUCCESS
21:45:23, 14 Mar.
ppp:PPP: CHAP_RESPONSE
21:45:23, 14 Mar.
ppp:PPP: LCP_GOOD_ACK
21:45:23, 14 Mar.
ppp:PPP: LCP_REQUEST
21:45:23, 14 Mar.
:PPPoE error: timeout
21:45:14, 14 Mar.
21:45:08, 14 Mar.
21:44:52, 14 Mar.
ptm0.101:VLAN VLAN_DATA connected
21:44:52, 14 Mar.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
21:44:52, 14 Mar.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
21:44:52, 14 Mar.
dsl:VDSL link Up: Down Rate=120923Kbps, Up Rate=19999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
21:43:01, 14 Mar.
:VLAN VLAN_DATA disconnected
21:43:01, 14 Mar.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:42:59, 14 Mar.
ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
21:42:52, 14 Mar.
dsl:VDSL Link Down: duration was 415017 seconds
00:04:25, 01 Jan.
00:04:14, 01 Jan.
00:04:13, 01 Jan.
ppp1:PPP: PPP INFO
00:04:07, 01 Jan.
ppp:PPP: IPCP_NAK
00:04:07, 01 Jan.
00:04:07, 01 Jan.
00:04:07, 01 Jan.
00:04:07, 01 Jan.
00:04:04, 01 Jan.
00:03:45, 01 Jan.
00:03:40, 01 Jan.
00:03:24, 01 Jan.
00:03:23, 01 Jan.
00:03:23, 01 Jan.
00:03:23, 01 Jan.
dsl:VDSL link Up: Down Rate=119617Kbps, Up Rate=28764Kbps, SNR Margin Down=15.30dB, SNR Margin Up=6.00dB
00:00:23, 01 Jan.
:WAN: ethernet as LAN
02:22:02, 10 Mar.
dsl:VDSL Link Down: duration was 16735 seconds
02:22:02, 10 Mar.
02:22:01, 10 Mar.
21:43:47, 09 Mar.
21:43:40, 09 Mar.
21:43:40, 09 Mar.
ppp1:PPP: PPP INFO
21:43:39, 09 Mar.
ppp:PPP: IPCP_NAK
21:43:39, 09 Mar.
21:43:39, 09 Mar.
21:43:39, 09 Mar.
21:43:39, 09 Mar.
21:43:38, 09 Mar.
21:43:29, 09 Mar.
21:43:24, 09 Mar.
21:43:08, 09 Mar.
21:43:08, 09 Mar.
21:43:08, 09 Mar.
21:43:08, 09 Mar.
dsl:VDSL link Up: Down Rate=121390Kbps, Up Rate=19999Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
21:41:17, 09 Mar.
21:41:17, 09 Mar.
21:41:06, 09 Mar.
21:41:01, 09 Mar.
dsl:VDSL Link Down: duration was 431746 seconds
21:45:53, 04 Mar.
21:45:52, 04 Mar.
21:45:52, 04 Mar.
ppp1:PPP: PPP INFO
21:45:51, 04 Mar.
ppp:PPP: IPCP_NAK
21:45:51, 04 Mar.
21:45:51, 04 Mar.
21:45:51, 04 Mar.
21:45:51, 04 Mar.
21:45:51, 04 Mar.
21:45:41, 04 Mar.
21:45:34, 04 Mar.
21:45:19, 04 Mar.
21:45:19, 04 Mar.
21:45:19, 04 Mar.
21:45:19, 04 Mar.
dsl:VDSL link Up: Down Rate=121048Kbps, Up Rate=28241Kbps, SNR Margin Down=15.30dB, SNR Margin Up=6.00dB
21:43:14, 04 Mar.
21:43:14, 04 Mar.
21:43:12, 04 Mar.
21:43:08, 04 Mar.
dsl:VDSL Link Down: duration was 432038 seconds
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: is SHINE affecting my connection?
I think it is more a hub/connection problems than it is interference  there have been other posts with similar problem and the most common one is hub resetting after 14 days like clockwork
Distinguished Guru
Distinguished Guru
Message 3 of 3
Easy solution is to get your own 3rd party router.
Problem solved.
