Message 1 of 2
keeps disconnecting
BT home hub 5, Software version 4.7.5.1.83.8.236.1.2
keeps dissconnecting, this has been going on for the past few weeks and it seems to be always mid day. i have checked the lines. but got nowhere. all that bellow means nothing to me so if someone can shred some light please, thank you.
13:23:38, 06 May.( 3490.300000) PTM over DSL is down after 1 minutes uptime
13:22:45, 06 May.( 3436.720000) CWMP: session closed due to error: Could not resolve host
13:22:42, 06 May.( 3434.280000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
13:22:42, 06 May.( 3434.270000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
13:22:38, 06 May.( 3429.980000) PTM over DSL is up
13:22:11, 06 May.( 3402.460000) CWMP: session closed due to error: Could not resolve host
13:22:11, 06 May.( 3402.440000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
13:22:11, 06 May.( 3402.430000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
13:22:10, 06 May.( 3401.640000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
13:22:07, 06 May.( 3398.750000) PTM over DSL is down after 17 minutes uptime
13:22:07, 06 May.( 3398.710000) PPPoE is down after 16 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
13:22:03, 06 May.( 3394.700000) PPP LCP Send Termination Request [User request]
13:21:23, 06 May.BLOCKED 6 more packets (because of Default policy)
13:21:22, 06 May.IN: BLOCK [15] Default policy (TCP [152.195.132.207]:443-​>[86.174.52.93]:59076 on ppp3)
13:20:52, 06 May.IN: BLOCK [15] Default policy (TCP [77.72.85.25]:56669-​>[86.174.52.93]:6969 on ppp3)
13:20:32, 06 May.IN: BLOCK [15] Default policy (TCP [191.101.167.223]:56691-​>[86.174.52.93]:54828 on ppp3)
13:20:26, 06 May.IN: BLOCK [15] Default policy (TCP [185.130.212.71]:11-​>[86.174.52.93]:6668 on ppp3)
13:20:23, 06 May.BLOCKED 4 more packets (because of Default policy)
13:20:22, 06 May.IN: BLOCK [15] Default policy (TCP [152.195.132.207]:443-​>[86.174.52.93]:59014 on ppp3)
13:20:21, 06 May.IN: BLOCK [15] Default policy (TCP [5.188.11.17]:46827-​>[86.174.52.93]:9834 on ppp3)
13:20:20, 06 May.IN: BLOCK [15] Default policy (TCP [85.93.20.244]:43003-​>[86.174.52.93]:9706 on ppp3)
13:20:15, 06 May.IN: BLOCK [15] Default policy (TCP [85.93.20.244]:43003-​>[86.174.52.93]:9746 on ppp3)
13:20:02, 06 May.IN: BLOCK [15] Default policy (TCP [185.130.212.71]:17-​>[86.174.52.93]:3086 on ppp3)
13:19:54, 06 May.IN: BLOCK [15] Default policy (TCP [5.188.11.111]:58277-​>[86.174.52.93]:6999 on ppp3)
13:19:32, 06 May.IN: BLOCK [15] Default policy (TCP [17.252.60.160]:5223-​>[86.174.52.93]:51912 on ppp3)
13:19:32, 06 May.BLOCKED 2 more packets (because of Default policy)
13:19:31, 06 May.IN: BLOCK [15] Default policy (TCP [17.252.60.160]:5223-​>[86.174.52.93]:51912 on ppp3)
13:19:22, 06 May.IN: BLOCK [15] Default policy (TCP [152.195.132.207]:443-​>[86.174.52.93]:58954 on ppp3)
13:19:17, 06 May.IN: BLOCK [15] Default policy (TCP [85.93.20.244]:43003-​>[86.174.52.93]:9641 on ppp3)
13:19:15, 06 May.IN: BLOCK [15] Default policy (TCP [185.130.212.71]:5-​>[86.174.52.93]:4380 on ppp3)
13:19:09, 06 May.IN: BLOCK [15] Default policy (TCP [191.101.167.223]:56691-​>[86.174.52.93]:53552 on ppp3)
13:19:08, 06 May.IN: BLOCK [16] Remote administration (TCP [62.173.138.153]:53580-​>[86.174.52.93]:80 on ppp3)
1 REPLY 1
Message 2 of 2
Re: keeps disconnecting
try quiet line test  dial 17070 option 2  should be quiet apart from announcement and best with corded phone
are you using the test socket with a filter even if you have a filtered faceplate to see if that helps by eliminating your internal wiring
can you post from HH5 - troubleshooting then helpdesk
