Kenny
Message 11 of 17
Re: line ststs help
doesnt work but get same details from dslstats
As a side note since bt phoned me at 19:15 i have not had 1 error online, before then i was getting a few every couple of mins. so they have done something.
kenny
bartman1967
Message 12 of 17
Re: line ststs help
Just reading this post and would like to add my 2p worth, my line speed is great 76Mb<> down and 18Mb<> up, but as you Kenny my line is interleaved and has been for 12 months, the interleaving level is always at 1419 and INP is alway 3, stats here:
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:	0
Last initialization procedure status:	0
Max:	Upstream rate = 31611 Kbps, Downstream rate = 93060 Kbps
Bearer:	0, Upstream rate = 19999 Kbps, Downstream rate = 79886 Kbps
Link Power State:	L0
Mode:			VDSL2 Annex B
VDSL2 Profile:		Profile 17a
TPS-TC:			PTM Mode(0x0)
Trellis:		U:ON /D:ON
Line Status:		No Defect
Training Status:	Showtime
		Down		Up
SNR (dB):	 6.0		 15.0
Attn(dB):	 15.2		 0.0
Pwr(dBm):	 12.5		 6.5
			VDSL2 framing
			Bearer 0
MSGc:		12		26
B:		55		237
M:		1		1
T:		64		42
R:		14		16
S:		0.0223		0.3781
L:		25104		5374
D:		1419		1
I:		70		127
N:		70		254
			Counters
			Bearer 0
OHF:		1880560773		2069494
OHFErr:		629		31
RS:		290238466		2860042
RSCorr:		853035651		466
RSUnCorr:	34431		0
			Bearer 0
HEC:		8522		0
OCD:		183		0
LCD:		183		0
Total Cells:	1264928552		0
Data Cells:	2872578770		0
Drop Cells:	0
Bit Errors:	0		0
ES:		111		27
SES:		0		0
UAS:		23		23
AS:		2021480
			Bearer 0
INP:		3.00		0.00
INPRein:	0.00		0.00
delay:		8		0
PER:		1.07		3.98
OR:		133.96		64.22
AgR:		80020.22	20063.54
Bitswap:	1617869/1617869		15147/15150
Total time = 1 days 9 hours 31 min 43 sec
FEC:		853035651		466
CRC:		629		31
ES:		111		27
SES:		0		0
UAS:		23		23
LOS:		0		0
LOF:		0		0
LOM:		0		0
Latest 15 minutes time = 1 min 43 sec
FEC:		51106		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Previous 15 minutes time = 15 min 0 sec
FEC:		421824		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Latest 1 day time = 9 hours 31 min 43 sec
FEC:		14667081		0
CRC:		6		0
ES:		1		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Previous 1 day time = 24 hours 0 sec
FEC:		45366916		5
CRC:		23		1
ES:		4		1
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Since Link time = 23 days 9 hours 31 min 19 sec
FEC:		853035651		466
CRC:		629		31
ES:		111		27
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
pbParams:
xdslcmd info --pbParams
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 31746 Kbps, Downstream rate = 93520 Kbps
Discovery Phase (Initial) Band Plan
US: (7,32) (871,1205) (1972,2782)
DS: (33,859) (1216,1961) (2793,3970)
Medley Phase (Final) Band Plan
	  VDSL Port Details		  Upstream		  Downstream
Attainable Net Data Rate:	    31746 kbps		    93520 kbps
Actual Aggregate Tx Power:	       6.5 dBm		     12.5 dBm
  VDSL Band Status	U0	U1	U2	U3	U4	D1	D2	D3
  Line Attenuation(dB):	3.6	19.0	28.1	N/A	N/A	10.2	23.9	36.0
Signal Attenuation(dB):	3.6	18.2	27.5	N/A	N/A	12.6	23.8	36.0
        SNR Margin(dB):	15.2	15.1	15.1	N/A	N/A	6.1	6.1	6.1
         TX Power(dBm):	6.7	23.9	6.2	N/A	N/A	8.2	7.9	7.1
I don't know if it will shed any light on your problems, but I have not been able to shake off the interleaving that DLM has set me.
Bart
What's slow about FTTC........DLM 😞
Kenny
Message 13 of 17
Re: line ststs help
well i dont know what changed last night when bt phoned me, 24 hrs later i have not had 1 crc or es error,
connected at 44mb and ip profile is just under that yet every speed test i have done today gives me in region of 47-50mb
interleaving has been decreased a little today as well, im now going to back away from looking at line stats as you can get a little wrapped up in them.
Im off to enjoy the speed hopefully it will last
kenny
bartman1967
Message 14 of 17
Re: line ststs help
Nice, lets hope it stays calm and quite....whisper back if needed...shhhhhh Smiley Tongue
Sylver123
Expert
Message 15 of 17
Re: line ststs help
Hi Kenny. How are you finding your Zyxel SBG 3300 router?
Do you still consider it was worth the money and the best
and most stable modem+router out of the rest of them
you've used so far including the HH5?
Kenny
Message 16 of 17
Re: line ststs help
Zyxel SBG 3300
A bit early to say at moment, if i didnt have the problem  with my line over weekend i would say yes i will let you know in a few days but for me its better than hh5
kenny
Sylver123
Expert
Message 17 of 17
Re: line ststs help
Thanks Kenny for responding.
I am considering getting one of these next wednesday.
I am hoping in the next few days you definitely notice your
line being more stable with it then the others you've tried.
