shermsta
Message 1 of 3
maximum data rate lower than data rate
Hi,
Data Rate: 20000 / 65308
Maximum Data Rate: 23647 / 65284
Noise Margin: 7.9 / 6.4
I really don't understand how my data rate is running faster than the maximum data rate?
Any ideas?
2 REPLIES 2
Message 2 of 3
Re: maximum data rate lower than data rate
If the latency has been set to fastpath, then the two figures can be very close, I would not worry about it, as the max data rate is only an approximation, and will change.
Message 3 of 3
Your data rate is determined by the condition of your line when sync occured. The max data rate is the rate attainable were you to re-sync at that point. Once synced your snrm will fluctuate and hence max data rate will also fluctuate. If you sync at a good time when your max rate is high, you will remain synced at that rate despite your snrm dropping (until a re-sync is forced if it drops too low) thus your actual will be higher than your max. Iam currently syncing at 53559 with a max attain of 50688 and an snrm of 5.8dB.
