Matt-S
Moderator-Retired
Message 21 of 30
Re: Broadband still not fixed
Hi @Dan22341,
Sorry to hear that your broadband connection is still not up and working.
The engineer that was out with you today was a phone line engineer and was only out to check the line as you had reported that you couldn't make calls. I'm not sure why he advised that he would call you later, the line fault was cleared as no fault found. I'm sorry that you were given incorrect information.
When I test the broadband I am not finding any hub connected would you be able to send post a photo of how you have the hub set up?
Matt
Dan22341
Message 22 of 30
i can't send a photo because my phone takes higher images then the site will allow me to post but here is how it is connected broadband cable connected from the hub to the phone socket with the phone connected with a microfilter hope this helps.
Matt-S
Moderator-Retired
Message 23 of 30
@Dan22341
What colour is the light on the hub and is the light flashing or solid?
Matt
Dan22341
Message 24 of 30
It has a solid orange light
Keith_Beddoe
Message 25 of 30
Connect it up like this, to see if it works. You should have a home hub 5, home hub 6, or smart hub 2.
Does your master socket look like the one shown above?
Dan22341
Message 26 of 30
i think mine is one that clips off
Matt-S
Moderator-Retired
Message 27 of 30
@Dan22341
Thanks, @Keith_Beddoe.
Can you make sure your hub is connected up the same way as @Keith_Beddoeh diagram?
I have also reported a fault to our supplier so that they can check the network there is not a network fault. If an engineer appointment is required we will call you and arrange the appointment with you.
Matt
Dan22341
Message 28 of 30
would be difficult for me to do i can't bend down due to a bad back and the socket is behind the sofa i think it would be best if a broadband engineer came out to me
Keith_Beddoe
Message 29 of 30
Does it just have one outlet, like this picture?
If it does, then unclip the front part, and the test socket will be behind.
Then connect it as shown below.
NTE 5C Test socket checkNTE 5C Test socket check
If you have two outlets on the front, then the home hub must plug into the small broadband socket. no filter is needed.
Keith_Beddoe
Message 30 of 30
That is fine, as you are entitled to free visits until the problem is sorted and you have service.
@Matt-S   should be able to arrange this.
