9kenny5
Message 1 of 3
multiple Infinity Problems
Okay, so first problem is that the home hub 3 is terrible at distributing speeds, when 2 computers are being used at the same time, one isn't able to even load pictures on pages!
Now onto the second part. Wired internet is 100 times slower than wireless somehow.
Third. The automatic wireless channel system is constantly messing up. Whenever I use it, it works for about a month then messes up, so I have to use a wired connection to then change the wireless channel to a manual one. And this seems to kill off some of the speed I receive.
And now, I can only access the internet during the mornings. So I'm having afternoons with a blinking orange broadband night instead of high speed internet! Apparently my local area connection is temporarily down, but it's happened for the past 2 days now...
So I'm confused as to if BT know they're really at providing internet? Also, any tips to how to fix any of the problems I have?
2 REPLIES 2
Distinguished Expert
Message 2 of 3
Re: multiple Infinity Problems
easiest way is to buy a replacement router like a tp link wr1043 nd
9kenny5
Message 3 of 3
Why should I pay for something that should be working?
