rob590
Message 21 of 39
Re: my day.
The restaurant below. If I was to use that one bearing in mind it never stops ringing I would miss out on hundreds of bookings. Should I have used that one and charged bt loss of earnings?
Message 22 of 39
Re: my day.
fair comment that was not clear in the first post
Distinguished Guru
Message 23 of 39
Re: my day.
Seemed clear to me as I repeated the bit from the first post.
If not, I'll try again 🙂
rob590
Message 24 of 39
Re: my day.
Just spoken to bt again. This time I'm told its the exchange. So first all phone lines are down, then it was a fault on personal lines only, then it was my wiring, then it was my equipment, now apparently its the exchange on my line only which will be fixed in 48 hours. My advice is dont use bt. Go sky or anything but bt
Message 25 of 39
Re: my day.
is anything shown here for your exchange  http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
Damian99
Message 26 of 39
Re: my day.
Yes move to sky or another service provider, cos they clearly don't have any such problems ever.
Message 27 of 39
Re: my day.
if only that was true - pick an ISP then check their forum
Distinguished Guru
Message 28 of 39
Re: my day.
But at least with Sky you don't have to talk to BT India
Message 29 of 39
Re: my day.
@Damian99 and all ISP's apart from cable use Openreach to provide and maintain the network so changing ISP's will not solve it and as posted just check out the forums of ISP's and you will see just the same problems
Message 30 of 39
Re: my day.
you don't have to talk to India with BT just come to the forumSmiley Wink
