Message 31 of 44
Re: new customer
just for ref 03/04/202020-04-03.png
Moderator
Moderator
Message 32 of 44
Re: new customer
Hi @stomper1  thanks for the updates. The broadband team are looking into this for me and have asked if you can confirm that you are connected with the BT Hub and is there anything else connected to the broadband when you are testing (even things that can't be disconnected) as the Svlan has been checked again and there is no congestion showing.
cheers
John
Message 33 of 44
Re: new customer
hi john
ive test with everything on, and ive tested with just one pc connected to the  hub.
during the day with everything connected I get download speeds up to 65mbps
but when evening comes I see my speed drop down to as low 24 mbps
ive tested with one pc when its dropped to 24mbps and ive even rebooted the hub at that time, but even that has not improved the speed  it seem that at that time of day my down load speed are restricted
cheers kevin
Message 34 of 44
Re: new customer
forgot to say I did notice I lost my internet around 17:15 yesterday but the router was still the same colour has if it was connected
cheers kevin
Message 35 of 44
Re: new customer
tested 08:54 everything connectedtested 08:54 everything connected
Message 36 of 44
Re: new customer
tested at 23:10 and as you can see my speed back up to what it should be
Message 37 of 44
Re: new customer
Message 38 of 44
Re: new customer
hi
phone bt this morning about the drop in speed that happens during the every evening without fail, the chap more or less called and liar.
while they run there test they state there nothing wrong with my line.
I stated I would pay for a bt engineer over time rate, to visit my home after hours to test my line
he stated this was not possible.
so how do I prove my case , the speed test screen shots  that ive taken to prove my speed related problem don't mean nothing
Message 39 of 44
Re: new customer
If your router stats show your connection speed is ok when you experience the drop in download speed the problem will not be with your line and it is only the connection speed the cs rep will be able to see. The problem shows classic signs of network congestion but the mods say your SVLAN isn't congested.
Message 40 of 44
Re: new customer
total agree with you,
but my argument with bt is they guarantee your speed will not drop below a certain amount when you sign up
mine drops nearly  less then half in that window
