blueingreen79
Message 1 of 27
new fibre service second engineervisit to activate fibre service
ive moved into s new build which now has a fibre modem installed so I have been able to order a n internet package through bt but have been told an engineer needs to visit prior to activation. (not until 10th jan) 😞 why would another visit be required ? given the modem is installed and apparently working and registered fine I thought this should be a simple activationwithout the need of an engineer to visit?
26 REPLIES 26
albertj
Expert
Message 2 of 27
Re: new fibre service second engineervisit to activate fibre service
Hey @blueingreen79
Welcome to the Community!
That is usually the case.
Can you enter your address on the Address Checker here: https://www.dslchecker.bt.com and post the results? Obviously, removing the address.
EDIT: Fixed URL
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
blueingreen79
Message 3 of 27
please can you check that url is correct?it gives me a blank page error 404
albertj
Expert
Message 4 of 27
Hi @blueingreen79
Oops, sorry about that!
For whatever reason, if I post the link it doesn’t work.
Please can you go to this website: https://www.dslchecker.bt.com/ and click the ‘Address Checker’ at the bottom, as I assume you won’t have a number yet.
blueingreen79
Message 5 of 27
correct no number yet
albertj
Expert
Message 6 of 27
OK 🙂
Please post the results from Address Checker. Removing the address.
blueingreen79
Message 7 of 27
is this useful?
ownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability DateFTTP Install ProcessOther Offerings
Availability Date
WBC FTTPUp to 1000Up to 220--Available2 Stage
VDSL Multicast------Available
albertj
Expert
Message 8 of 27
Ideally, I would need the whole page that you get.
But it does show that while you can get FTTP, it requires a two stage install (two engineers). This is what BT sees as well when ordering for your address.
Can you post a picture of the box in your home? There has been a few models, otherwise I would post a picture, but look for an Openreach Logo.
The rest of the page would be great, as this shows if they are aware of this modem.
blueingreen79
Message 9 of 27
Sage
Message 10 of 27
You say the ONT is installed, registered and working. What colour are the lights?
