blueingreen79
Message 11 of 27
Re: new fibre service second engineervisit to activate fibre service
Message 12 of 27
Tricky to tell from a photo if the PON light is steady or flashing green. 😀
Message 13 of 27
Have you tried connecting the BT Home hub`s WAN port to the Ethernet port on the ONT?
blueingreen79
Message 14 of 27
hey are all stable
Message 15 of 27
In which case all is good to go.
blueingreen79
Message 16 of 27
asin I can plug my router in and expect service?!
iniltous
Recognised Expert
Message 17 of 27
As the ONT is installed and appears as if the PON light is lit, it kinda suggests that a one stage install is appropriate,  perhaps the database indicating a two strange install is wrong, have you ordered your BT service yet ?, have they delivered any kit ?
AFAIK , a two stage install requires the ‘fibre’ to be provided to your address ( stage 1)  and then brought into service, ( stage 2) as the fibre apparently is already there ( because it’s a new build and provided before you were handed the keys ) I suspect all that is now needed is the router ( when it’s delivered ) connecting and the bar code of the ONT registered and authorised by a single engineer visit
Message 18 of 27
You could try, as shown below.
Message 19 of 27
You may however end up on this page http://62.6.38.125/index.html
blueingreen79
Message 20 of 27
thanks all for your help  decided in the end to give bt a call I was getting infuriated with long answer times hence onto the forum here turns out there is a faulty port on the ont am going to plug in my apple airport anyway and see what happens 🙂
