Message 1 of 4
no IPv6 on FTTP
Hello,
I have recently had BT FTTP installed, however I have been unable to get an IPv6 address. I have been trying for ages with various different settings on pfSense via PPPoE, however upon trying the supplied BT Smart Hub 2, that does not get any IPv6 connectivity either.
Are there any ways to fix this?
Thanks.
3 REPLIES 3
Message 2 of 4
Re: no IPv6 on FTTP
These are my pfSense IPv6 settings for BT (also note that you can have 1500 MTU) but if you don't get an address with SH2 either then clearly an issue with your connection rather than your router.  You might need to get a MOD to investigate.ipv6.png
____________________________________________
BT FTTP 500/75 + pfSense + 4 x UniFi Wifi 6 Pro
Message 3 of 4
Re: no IPv6 on FTTP
Thanks for your response. These are the settings I am using on pfSense - so I think I need to wait for a mod.
Message 4 of 4
Re: no IPv6 on FTTP
Did you ever get this working?  I have the exact same issue
