Distinguished Guru
Message 11 of 25
Re: no internet since 23rd december
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 12 of 25
I’ll keep an eye out but not come across any issues descried either on ADSL, VDSL or FTTP and most of the work I do is Broadband Repair.
Message 13 of 25
Had it confirmed, there’s a National Problem affecting PPPoE on ECI DSLAMS.
mrial
Message 14 of 25
thanks for the information starwire2000.
My issue was solved by a moderator in another thread, but something else seems to have cropped up.
My connection came back on the 2nd january all was fine with a 80/20 connection then after 24 hours the hub disconnects again. It alternated between orange and blue lights.
I couldnt get the hub to connect so i tried the new netgear and it connected first time perfectly, but now i seem to only have a 63/20 connection.
Is that speed due to the netgear? i wanted to see what i would get with the hub but i cant get it to connect (ive tried resetting)
Message 15 of 25
Apparently some update was applied to ECI Cabs and it caused PPPoE Issues.
Resetting the Card may resolve it, if not then a Lift and Shift onto a new port might.
If that doesn’t help there’s nothing more a field Engineer can do and the issue needs to be dealt with by the back office support guys.
mrial
Message 16 of 25
thanks for the reply.
Who would i need to speak to, to get that done?
Sage
Sage
Message 17 of 25
Don't you now have a connection? If so the fix has been applied to your cab already.
mrial
Message 18 of 25
i have a connection with the netgear router not the home hub and its reduced to 63012 kbps instead of the solid 80 i had for the last couple years.
Sage
Sage
Message 19 of 25
But that has nothing to do with the ECI cab issue.
Post the connection stats from the netgear.
mrial
Message 20 of 25
ADSL LinkDownstreamUpstream
Connection Speed63012 kbps20000 kbps
Line AttenuationD0( 3.2) D1( 6.7) D2( 11.4) dBU0( 0.1) U1( 5.1) U2( 8.0) U3(N/A) U4(N/A) dB
Noise MarginD0( 8.4) D1( 8.3) D2( 8.3) dBU0( 6.7) U1( 6.3) U2( 6.0) U3(N/A) U4(N/A) dB
