Sage
Sage
Message 21 of 25
Re: no internet since 23rd december
Your noise margin is a little on the high side which explains the loss in speed. Try connection to the test socket with a filter and see if it improves.
Also do a quiet line test 17070 option 2, any noise report a line fault on 151. Do not mention broadband.
mrial
Message 22 of 25
no noise detected on the phone line.
i plugged straight into the test socket with a filter and this is the result:
ADSL Link
DownstreamUpstream
Connection Speed63104 kbps20000 kbps
Line AttenuationD0( 3.2) D1( 6.7) D2( 11.3) dBU0( 0.1) U1( 5.1) U2( 8.0) U3(N/A) U4(N/A) dB
Noise MarginD0( 8.6) D1( 8.4) D2( 8.4) dBU0( 8.3) U1( 6.3) U2( 6.0) U3(N/A) U4(N/A) dB
Sage
Sage
Message 23 of 25
Is there a max attainable figure given by the netgear?
mrial
Message 24 of 25
no, no other info given.
mrial
Message 25 of 25
its gotten worse
ADSL LinkDownstreamUpstream
Connection Speed54148 kbps20000 kbps
Line AttenuationD0( 3.1) D1( 6.6) D2( 11.2) dBU0( 0.1) U1( 5.0) U2( 7.8) U3(N/A) U4(N/A) dB
Noise MarginD0( 11.0) D1( 10.9) D2( 10.9) dBU0( 6.4) U1( 6.2) U2( 6.0) U3(N/A) U4(N/A) dB
