hi this is my package
average 67mb download speed but i dont get anywhere near that since i moved house i now get 15-20
has serveral engineer visits and another one in about a week which will probably solve nothing.
any suggestions before think about leaving its just too slow when everyone is using the wifi etc
as you have posted the average speed is 67mb - stress average that means some people will get faster and some slower but when averaged that works out at 67mb unfortunately you are on the slower side
post stats if hh6 then advanced settings then technical log information
enter phone number and post results delete number https://www.btwholesale.com/includes/adsl/main.html
Telephone Number -------- on Exchange CHINGFORD is served by Cabinet 1
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper High Low High Low Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsVDSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean) | 41 | 27.4 | 7.6 | 5.4 | 25 | Available | Available | -- | |
VDSL Range B (Impacted) | 40 | 24.6 | 7.5 | 4.8 | 20 | Available | Available | -- | |
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | |||
WBC ADSL 2+ | Up to 15 | -- | 8.5 to 19 | Available | -- | -- | |||
WBC ADSL 2+ Annex M | Up to 15 | Up to 1.5 | 8.5 to 19 | Available | -- | -- | |||
ADSL Max | Up to 7 | -- | 6 to 8 | Available | -- | -- | |||
WBC Fixed Rate | 2 | -- | -- | Available | -- | -- | |||
Max Observed Downstream Speed (Mbps) | 22.39 | ||||||||
Max Upstream Observed Speed (Mbps) | 5.18 | ||||||||
Observed Date | 2019-03-30 | ||||||||
VDSL Multicast | -- | -- | -- | Available | -- | -- | |||
ADSL Multicast | -- | -- | -- | Available | -- | -- | |||
Bridge Tap | N | ||||||||
VRI | N | ||||||||
NTEFaceplate | N | ||||||||
Last Test Date | 21-03-2019 |
as you can see the range is 41/27mb so you are not going to get anywhere near 67mb
need hub stats
try quiet line test dial 17070 option 2 should be silent and best with corded phone
have you tried using the test socket with a filter - even if you currently have a filtered faceplate
1. Product name: | BT Home Hub |
2. Serial number: | +068543+NQ52212704 |
3. Firmware version: | Software version 4.7.5.1.83.8.264 (Type A) Last updated 02/03/19 |
4. Board version: | BT Hub 5A |
5. DSL uptime: | 0 days, 00:22:14 |
6. Data rate: | 5135 / 21309 |
7. Maximum data rate: | 5135 / 27430 |
8. Noise margin: | 5.9 / 9.2 |
9. Line attenuation: | 29.5 / 25.7 |
10. Signal attenuation: | 29.4 / 21.9 |
11. Data sent/received: | 845.5 MB / 21.5 GB |
12. Broadband username: | bthomehub@btbroadband.com |
13. BT Wi-fi: | Yes |
14. 2.4 GHz Wireless network/SSID: | BTHub5-HWSF |
15. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
16. 2.4 GHz Wireless security: | WPA2 |
17. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
18. 5 GHz Wireless network/SSID: | BTHub5-HWSF |
19. 5 GHz Wireless connections: | Disabled |
20. 5 GHz Wireless security: | WPA2 |
21. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
22. Firewall: | Default |
23. MAC Address: | 54:64:d9:27:d0:f2 |
24. Modulation: | G.993.2 Annex B |
25. Software variant: | AA |
26. Boot loader: | 1.0.0 |
i currently took the faceplate off and using a micro filter no difference
dont have a house phone connected so not able to call that number
are the hub stats from the test socket? if not can you connect to test socket with filter and repost stats
the most basic test is to check for a dial tone as your broadband will work with only 1 wire connected but slowly whereas you need both wires connected for dial tone
if you do not check phone and the problem is in your home then you will be charged £85 forthe engineer callout but if outside your home there is no cost corded phone is only about £5 - good investment as can save cost of engineer visit
im guessing test socket is behind the faceplate? which is what i posted
so with a house phone connected the speeds should rise?
No, its just a diagnostic tool.
Hi @JIIason welcome to the forum and thanks for posting. Was the estimate for your address before you moved home or was this the estimate you were given when you moved?
Have you had a chance to connect the the test socket and if so how did you get on?
Cheers
John
