Barry57
Expert
Message 81 of 366
Re: planning to get myself an unlocked openreach modem
Swapped over to the unlocked ECI/r  from the unlocked HG612 3B
So far so good, slightly quicker and interleave is off 🙂  I'll see how it goes this week.
One thing is noticable, the eci seems to run cooler.
uncleiven
Message 82 of 366
May be a dumb question but what's the different between a locked and an unlocked VDSL modem.... What should I be looking to buy as some descriptions from the auctions sites don't specify.
soapy
Expert
Message 83 of 366
the only difference is the unlocked modem you can bring up the line stats and the standard locked modem you cannot. they both work fine, just some people like to see the stats
Distinguished Expert
Message 84 of 366
and you can turn some options off and on, on an unlocked modem.
To say thanks for a helpful answer, please click the white star
Barry57
Expert
Message 85 of 366
As legitimise_sailing highlighs
They are excellent with the added features, plus according to the people on a more techincal forum give faster speeds.
Been using the unlocked HG612 3B with BT software removed and its been excellent.
Back on the unlockled ECI/r at the moment  & upto now lines is great. The ECI/r runs cooler which might come into its own in summer time.
uncleiven
Message 86 of 366
Ok cool, so looking at my PCP it seems to be an ECI variety (smaller with 1 door) so I will look to get one from the various places online :).
Can locked ones be unlocked fairly easily?
Barry57
Expert
Message 87 of 366
Hi
I'm not in IT {or have any experiance coding / soldering} so I got both of mine already pre configured of that well know auction site.  🙂
Barry57
Expert
Message 88 of 366
Forgot to menition with the unlocked ECI/r  Lan2 works as well.
Had no issues with updates/disconnects - It very simular to the hg612-3b.
JezP
Newbie
Message 89 of 366
Hi Barry how do you know your interleave is off is this something i can see in the stats? btw i have a unlocked hg612.
Barry57
Expert
Message 90 of 366
Hi JezP
There good aren't they 🙂 Mine shows all the line details with a the software.
I belive its from this command ?
xdslcmd info --stats
I'm not a programmer or coder so please double check - just in case :oops:
Barry
