Barry57
Expert
Message 31 of 366
Re: planning to get myself an unlocked openreach modem
Just been reading about those ZyXEL's ( SBG3300-N & VMG8324 )
They look like they have the same chip brand as the HG612 3B ( broadcom) if I'm reading the info correctly ?
For me after the helpful advice its an unlocked ECI/r to pair with the cab.
Kenny
Message 32 of 366
Its a pretty straight forward to set up so if you get one let me know and i will send you screen shots of settings, there is a thread on here somewhere about the settings
kenny
Sylver123
Expert
Message 33 of 366
kenny
Thanks kenny. Please keep me informed during this week if it was definitely worth it and your
connection is definitely more stable and able to maintain your proper estimated speed.
I came across this website below on how to set up this modem+router for use with BT Infinity.
http://fullofcheese.com/bt-infinity-vdsl-modem-configuration-zyxel-sbg3300/
Are these the same settings you used? also, did you update to the
latest firmware for this modem+router?
Kenny
Message 34 of 366
yes thats the settings i used and yes upgraded to latest firmware.
If i have any drops or anything i will let you know
kenny
Sylver123
Expert
Message 35 of 366
Thanks a lot kenny. Hopefully this modem+router will be the best one and is
able to keep your connection stable and without dropping out so much.
Distinguished Expert
Message 36 of 366
It seems obvious to me that a lot of the problems are caused by the mis-use of TR069 to throttle connections using the BTAgent in the modem and PTM 301 on the router. This is easily solved by turning these options off in an unlocked modem or using 3rd party hardware that doesn't respond to the commands.
To say thanks for a helpful answer, please click the white star
Kenny
Message 37 of 366
latest stats nearly 3 days since i pulled the power plug  out by tripping over it.
however no drops since then and despite stated connection speed below every speed test is giving me 45mb plus
Uptime:          2 days 23 hours 39 min 5 sec
    Downstream Upstream
Attenuation (dB):        24.8  0.0
Connection speed (kbps): 43328  5935
SNR margin (dB):         6.4  6.0
Power (dBm):             12.6  2.0
Interleave depth:        847  1
INP:                     3.00  0
RSCorr/RS (%):           0.2822  0.0164
RSUnCorr/RS (%):         0.0015  0.0000
ES/hour:                 1.11  0.71
Sylver123
Expert
Message 38 of 366
Thanks Kenny for the update.
I have took the plunge and place an order for the
ZyXEL SBG3300-N Router earlier this morning.
It should be delivered by tuesday.
Sylver123
Expert
Message 39 of 366
Well I received my ZyXEL SBG3300-N yesterday and so
far I am very pleased with this modem+router.
I have just noticed that my interleave depth is quite
high at 949 and so suggests that I am receiving a
lot of noise or other interference.
so far I have been connected for 19 hours and
without any dropouts since I connected the
ZyXEL SBG3300-N to my line yesterday afternoon.
    VDSL Training Status:   Showtime
                    Mode:   VDSL2 Annex B
            VDSL Profile:   Profile 17a
            Traffic Type:   PTM Mode
             Link Uptime:   0 day: 19 hours: 3 minutes
       VDSL Port Details       Upstream         Downstream
               Line Rate:      8.354 Mbps       48.534 Mbps
    Actual Net Data Rate:      8.334 Mbps       48.447 Mbps
          Trellis Coding:         ON                ON
              SNR Margin:        6.1 dB            6.5 dB
            Actual Delay:          0 ms              8 ms
          Transmit Power:        4.5 dBm          12.6 dBm
           Receive Power:       -7.0 dBm         -12.8 dBm
              Actual INP:        0.0 symbols       3.0 symbols
       Total Attenuation:       11.5 dB           25.5 dB
Attainable Net Data Rate:      8.502 Mbps       58.822 Mbps
Friday
Message 40 of 366
Can you give me a bit more info on what to do with TR069 and PMT 301, the only thing I know about those is to stay clear of the wife!
I know how to switch the BTagent off but I'm unsure what the other two do.
