mso6jx
Message 31 of 37
Re: "ERR_SSL_VERSION_OR_CIPHER_MISMATCH Unsupported protocol" when trying to access Social
Thank you!
Was seeing 'Unsupported protocol' for Facebook, and switching off BT Parental Controls made no difference.
This resolved my issue immediately:
- switched BT Parental Controls back on
- saved new random 'Choose extra settings for homework time' settings (Saturday-Sunday 03:00-04:00)
The issue returns after a few minutes if I reset 'homework time' to blank, so I'll just keep it set until BT fixes this bug.
Sambob
Message 32 of 37
Yes, they not only need to fix this bug, but additionally a "blocked" webpage should display when trying to access any website that their parental controls block so you know what is blocking it. Getting a generic protocol error is misleading and can lead to hours wasted trying to get to the bottom of an issue caused by their own filter. I know it wasted a lot of my time and even their own tech supports time who were clueless. This is especially compounded when dealing with other BT internet issues... frustrated and stressed are just a few mild feelings I've had with BT lately.
slee65907
Message 33 of 37
I've also fallen fowl of this bug. I'm a BT customer but the problem is people trying to access my work site hit this error. It's only BT people and I've spent a lot of my time on this.
https://opendirective.net/2020/04/17/the-open-communication-symbols-ecosystem/
The last post makes me think it's my site getting blocked by your controls and the fact that people are not getting a error explaining it is rather patheric to be honest and a real time waster for all involved. I expect Better form BT
Pleas eexplain if the problem is tha **bleep** is getting balckisted somewhere why it works for me? Perhasp I resolved it ages ago, I cannot recall.
Please tell me how to get this site whitelisted? My work is for those that support people with severere disbilities.
More importantly
cellyb
Message 34 of 37
 3 Modems, 1upgrade, 4  (long) phones call and 6 months . In desperation, after another month of running out of mobile data, I finally asked Google and came across your solution.
It worked!!!!. Thank you
Now it would be great if you can get this resource-saving solution across to the BT technical support.
Sambob
Message 35 of 37
One of the mods needs to forward this onto BT support. It’s farcical how this is still an ongoing issue for some users. All because the routers software has been poorly designed.
Tags (1)
slee65907
Message 36 of 37
Exactly! there should a be a easy and clearly signposted mechanism to have false rejections fixed. Plus a message that lets you know it is the problem rather than an obscure error with many possible causes.
Come on BT!
slee65907
Message 37 of 37
Oh, and clear confirmation that is has been fixed!!! not radio silence.
This affects both cistomers and non customers
