Thumbz1974
Message 1 of 9
"Unlimited" Infinity - 80 meg to the house, but can't stream video????
I have had Infinity (Allegedly unlimited) for a number of years without problems.  Recently all of my devices have had speed issues when loading pages, downloading files / content and (most often) streaming video.  All devices have the latest software upgrades and are set as correctly as I can. I have had the BT hub replaced, but still no improvement.  I tried using BT powerline adaptors, also without improvement, just lightening my wallet to the tune of £99!  I have tried selecting different channels, but keep coming to the conclusion BT have "optimised" my service to suit everyone else but me... BT engineer tested the line and I got almost 80meg to the house and nearly 47meg to the computer wirelessly... I'm at my wits end!  HELP......
8 REPLIES 8
Distinguished Guru
Message 2 of 9
Re: "Unlimited" Infinity - 80 meg to the house, but can't stream video????
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
If not, I'll try again 🙂
Thumbz1974
Message 3 of 9
1. Product name:
BT Home Hub
2. Serial number:
+076272+NQ41947166
3. Firmware version:
Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version:
BT Hub 5A
5. VDSL uptime:
0 days, 06:59:08
6. Data rate:
19999 / 77462
7. Maximum data rate:
27082 / 77607
8. Noise margin:
15.2 / 6.5
9. Line attenuation:
0.0 / 8.3
10. Signal attenuation:
0.0 / 8.4
11. Data sent/received:
37.7 MB / 198.3 MB
12. Broadband username:
13. BT Wi-fi:
Message 4 of 9
run btspeedtester and when first test completes then run diagnostic test
btspeedtester
Thumbz1974
Message 5 of 9
Won't let me run the speed tester... says I don't have flash installed... I have installed this THREE times...
Message 6 of 9
have you tried a different browser?
Thumbz1974
Message 7 of 9
Tried another speed tester as BT reckon I dont have software installed that my computer says I do... 68+ d/l and 16+ u/l
chris6273
Recognised Expert
Message 8 of 9
Try running it in Google Chrome which has Flash natively installed in it :).
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
dfenceman
Expert
Message 9 of 9
Hi Thumbz1974,
Try this, it should take you straight to the Further Diagnostics :-
http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
Best regards,
dfenceman
