Message 11 of 31
Re: "Upgraded" to BT Fibre Essentials - "Downgrade" in speed.
@aston007
Just as I asked in message 2
Message 12 of 31
Message 13 of 31
Apologies - yes you did. Thanks!
Message 14 of 31
That's the log, we need the stats detailing your line rate etc.
Message 15 of 31
The heading is information not logs
Message 16 of 31
Broadband statsBroadband stats
Message 17 of 31
The speed is terrible and well below estimated range
are you using the test socket with a filter even if you have a filtered faceplate to see if that increases speed. When you use test socket can you repost router stats
when in test socket check there is no dial tone at any extension socket whether in use or not
Message 18 of 31
Thanks imjolly.
It's comforting that someone else believes this is dire.
The line to the router does come from the BT socket and has a faceplate on it (two inputs on the front). I will try to circumvent the filter and remove the faceplate, but be assured that no other internal extensions run off this main socket.
Since the service has just been installed, I have requested that the engineer returns. We'll see what the next 7 days brings.
Many, many thanks.
Message 19 of 31
If that's the case then normally you don't need to check using the test socket, but we just need to confirm.
Sage
Message 20 of 31
The OP can request an engineer free of charge in these circumstances within 21 days. How long has the OP been upgraded?
