Wren
Message 11 of 19
Re: repetitive loss of connection to internet
@Keith_Beddoe
appreciate what you are saying i do;
but I've just found the right way to solve all this -
I went to here - http://bt.custhelp.com/app/answers/detail/a_id/13897/~/video--how-to-test-your-phone-line-and-check-...
and clicked an option; then the chat box came up to talk with problem-fixing people; the helper there tested both my broadband and my phoneline; and said that my phoneline is fine, and not having a landline phone isn't an issue; and they found my real problem is that I have a fault on my hub; so they then ordered me a new one 🙂
Message 12 of 19
Sounds like the normal answer from the helpdesk, I would be surprised if a new hub makes any difference.
Line testing.
They cannot detect high resistance connections using the line tester. Its a very basic test for either loop, battery, or earth connection, or in some cases a break in the copper circuit somewhere.
Message 13 of 19
A good old-fashioned Mark1 eardrum can detect a lot of things technology can't. :smileywink:
Message 14 of 19
Exactly :smileywink:
Wren
Message 15 of 19
@Keith_Beddoe
please don't make me sad 😞
I cannot cope with a landline phone for the following reasons -
I can't afford it;
bt know i don't have one, so if someone breaks in my flat they could make phonecalls just plugging in their cheap £5 phone, so it's obvious it's not me, buut if i get a phone and use the phoneline then bt can quite logically say but you have a phone and have used it;
people could break in and use my cheapo £5 phone to make not-cheapo phonecalls, that i can't then afford to pay;
So if my new hub doesn't solve the problem then will an engineer have to test the line; the chat helper said they tested it?
Tags (1)
Message 16 of 19
@Wren wrote:
@Keith_Beddoe
I can't afford it;
What £5, you don't have to make any chargeable calls.
bt know i don't have one, no they don't so if someone breaks in my flat they could make phonecalls just plugging in their cheap £5 phone, so it's obvious it's not me, buut if i get a phone and use the phoneline then bt can quite logically say but you have a phone and have used it; they would say that anyway as they have no idea whether you have a phone or not.
Do people normally break into flats in order to use the phone?
 You could always just borrow one.
Wren
Message 17 of 19
@licquorice
@licquorice wrote:
@Wren wrote:
@Keith_Beddoe
I can't afford it;
now you are being rude;
also please do not add sarcastic comments into my post, as though an arrogant teacher sneering at a schoolchild.
I think the accounts department may have noticed I don't have a phone.
Yes thankyou for your snide and thoughtless comments; I will look into borrowing an engineer if I find I need one at a later date. Though I wasn't planning on keeping him.
Your seeming ability to do everyone's job at bt better than they can is wonderful 😕 but I found someone who was polite to help me, and felt no need to put me down in order to feel good about himself.
Message 18 of 19
I can assure you the accounts department have absolutely no knowledge of whether you have a phone or not, it is of no interest to them whatsoever.
Moderator
Moderator
Message 19 of 19
Hi Everyone,
Please keep it friendly, we want community members to feel comfortable asking and answering questions.
Cheers
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
