Message 1 of 7
safe to use Home Hub 5A as a modem again?
About two years ago my HH5 model A started contimually disconnecting, so I attached it to the separate white modem that came with the HH3 and the connection became relatively stable again. I can't remember if that was before it received the latest firmware version 4.7.5.1.83.8.204.1.11 (Type A) or not. Please let me know if you think HH5 A connection issues have since generally been fixed and if it would be safe to use the HH5 as a modem again.
6 REPLIES 6
Message 2 of 7
Re: safe to use Home Hub 5A as a modem again?
no reason not to use it at all
Message 3 of 7
OK, thanks John, I'll give it a whirl
Sage
Message 4 of 7
As it was fronted by the Openreach modem it's possible the firmware updates weren't delivered. You may have to wait for that to happen once you remove the modem.
Message 5 of 7
well, that didn't work. Connection drops every few minutes so it looks like it's back to going via the Openreach modem again:
15:26:54, 23 Apr.
(199990.470000) WAN operating mode is VDSL
15:26:54, 23 Apr.
(199990.470000) Last WAN operating mode was VDSL
15:26:53, 23 Apr.
(199989.050000) PPP IPCP Receive Configuration ACK
15:26:53, 23 Apr.
(199989.040000) PPP IPCP Send Configuration Request
15:26:53, 23 Apr.
(199989.040000) PPP IPCP Receive Configuration NAK
15:26:53, 23 Apr.
(199989.040000) PPP IPCP Send Configuration ACK
15:26:53, 23 Apr.
(199989.030000) PPP IPCP Receive Configuration Request
15:26:53, 23 Apr.
(199989.020000) PPP IPCP Send Configuration Request
15:26:51, 23 Apr.
(199987.760000) PPPoE is up -​ Down Rate=10678000Kbps, Up Rate=2321000Kbps; SNR Margin Down=6.2dB, Up=6.1dB
15:26:51, 23 Apr.
(199987.750000) CHAP authentication successful
15:26:51, 23 Apr.
(199987.700000) CHAP Receive Challenge
15:26:51, 23 Apr.
(199987.700000) Starting CHAP authentication with peer
15:26:51, 23 Apr.
(199987.700000) PPP LCP Receive Configuration ACK
15:26:51, 23 Apr.
(199987.700000) PPP LCP Send Configuration Request
15:26:51, 23 Apr.
(199987.700000) PPP LCP Receive Configuration Reject
15:26:51, 23 Apr.
(199987.690000) PPP LCP Send Configuration ACK
15:26:51, 23 Apr.
(199987.690000) PPP LCP Receive Configuration Request
15:26:51, 23 Apr.
(199987.690000) PPP LCP Send Configuration Request
15:26:01, 23 Apr.
(199937.510000) PTM over DSL is up
15:25:27, 23 Apr.
(199903.720000) PTM over DSL is down after 8 minutes uptime
15:25:27, 23 Apr.
(199903.710000) PPPoE is down after 7 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
15:25:22, 23 Apr.
(199898.480000) PPP LCP Send Termination Request [User request]
15:18:03, 23 Apr.
(199459.720000) WAN operating mode is VDSL
15:18:03, 23 Apr.
(199459.720000) Last WAN operating mode was VDSL
15:18:02, 23 Apr.
(199458.270000) PPP IPCP Receive Configuration ACK
15:18:02, 23 Apr.
(199458.270000) PPP IPCP Send Configuration Request
15:18:02, 23 Apr.
(199458.260000) PPP IPCP Receive Configuration NAK
15:18:02, 23 Apr.
(199458.260000) PPP IPCP Send Configuration ACK
15:18:02, 23 Apr.
(199458.260000) PPP IPCP Receive Configuration Request
15:18:02, 23 Apr.
(199458.250000) PPP IPCP Send Configuration Request
15:18:01, 23 Apr.
(199456.960000) PPPoE is up -​ Down Rate=8237000Kbps, Up Rate=1482000Kbps; SNR Margin Down=6.3dB, Up=6.6dB
15:18:01, 23 Apr.
(199456.950000) CHAP authentication successful
15:18:01, 23 Apr.
(199456.900000) CHAP Receive Challenge
15:18:01, 23 Apr.
(199456.900000) Starting CHAP authentication with peer
15:18:01, 23 Apr.
(199456.890000) PPP LCP Receive Configuration ACK
15:18:01, 23 Apr.
(199456.890000) PPP LCP Send Configuration Request
15:18:01, 23 Apr.
(199456.890000) PPP LCP Receive Configuration Reject
15:18:01, 23 Apr.
(199456.880000) PPP LCP Send Configuration ACK
15:18:01, 23 Apr.
(199456.880000) PPP LCP Receive Configuration Request
15:18:01, 23 Apr.
(199456.880000) PPP LCP Send Configuration Request
15:17:10, 23 Apr.
(199406.510000) PTM over DSL is up
15:16:40, 23 Apr.
(199376.790000) PTM over DSL is down after 0 minutes uptime
15:15:47, 23 Apr.
(199323.730000) PTM over DSL is up
15:15:16, 23 Apr.
(199292.250000) PTM over DSL is down after 1 minutes uptime
15:15:16, 23 Apr.
(199292.240000) PPPoE is down after 1 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
15:15:11, 23 Apr.
(199286.960000) PPP LCP Send Termination Request [User request]
15:14:12, 23 Apr.
(199228.440000) WAN operating mode is VDSL
15:14:12, 23 Apr.
(199228.440000) Last WAN operating mode was VDSL
15:14:11, 23 Apr.
(199226.990000) PPP IPCP Receive Configuration ACK
15:14:11, 23 Apr.
(199226.860000) PPP IPCP Send Configuration Request
15:14:11, 23 Apr.
(199226.860000) PPP IPCP Receive Configuration NAK
15:14:11, 23 Apr.
(199226.860000) PPP IPCP Send Configuration ACK
15:14:11, 23 Apr.
(199226.860000) PPP IPCP Receive Configuration Request
15:14:10, 23 Apr.
(199226.640000) PPP IPCP Send Configuration Request
15:14:09, 23 Apr.
(199225.350000) PPPoE is up -​ Down Rate=7615000Kbps, Up Rate=1315000Kbps; SNR Margin Down=6.9dB, Up=6.5dB
15:14:09, 23 Apr.
(199225.340000) CHAP authentication successful
15:14:09, 23 Apr.
(199225.220000) CHAP Receive Challenge
15:14:09, 23 Apr.
(199225.220000) Starting CHAP authentication with peer
15:14:09, 23 Apr.
(199225.220000) PPP LCP Receive Configuration ACK
15:14:09, 23 Apr.
(199225.100000) PPP LCP Send Configuration Request
15:14:09, 23 Apr.
(199225.100000) PPP LCP Receive Configuration Reject
15:14:09, 23 Apr.
(199224.980000) PPP LCP Send Configuration ACK
15:14:09, 23 Apr.
(199224.980000) PPP LCP Receive Configuration Request
15:14:09, 23 Apr.
(199224.980000) PPP LCP Send Configuration Request
15:13:18, 23 Apr.
(199174.490000) PTM over DSL is up
15:12:48, 23 Apr.
(199143.940000) PTM over DSL is down after 1 minutes uptime
15:12:48, 23 Apr.
(199143.930000) PPPoE is down after 0 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
15:12:42, 23 Apr.
(199138.740000) PPP LCP Send Termination Request [User request]
15:11:46, 23 Apr.
(199082.640000) WAN operating mode is VDSL
15:11:46, 23 Apr.
(199082.640000) Last WAN operating mode was VDSL
15:11:45, 23 Apr.
(199081.200000) PPP IPCP Receive Configuration ACK
15:11:45, 23 Apr.
(199081.190000) PPP IPCP Send Configuration Request
15:11:45, 23 Apr.
(199081.190000) PPP IPCP Receive Configuration NAK
15:11:45, 23 Apr.
(199081.180000) PPP IPCP Send Configuration ACK
15:11:45, 23 Apr.
(199081.180000) PPP IPCP Receive Configuration Request
15:11:45, 23 Apr.
(199081.180000) PPP IPCP Send Configuration Request
15:11:44, 23 Apr.
(199079.890000) PPPoE is up -​ Down Rate=9306000Kbps, Up Rate=1697000Kbps; SNR Margin Down=5.8dB, Up=6.0dB
15:11:44, 23 Apr.
(199079.880000) CHAP authentication successful
15:11:44, 23 Apr.
(199079.840000) CHAP Receive Challenge
15:11:44, 23 Apr.
(199079.840000) Starting CHAP authentication with peer
15:11:43, 23 Apr.
(199079.840000) PPP LCP Receive Configuration ACK
15:11:43, 23 Apr.
(199079.840000) PPP LCP Send Configuration Request
15:11:43, 23 Apr.
(199079.840000) PPP LCP Receive Configuration Reject
15:11:43, 23 Apr.
(199079.830000) PPP LCP Send Configuration ACK
15:11:43, 23 Apr.
(199079.830000) PPP LCP Receive Configuration Request
15:11:43, 23 Apr.
(199079.830000) PPP LCP Send Configuration Request
15:10:53, 23 Apr.
(199029.490000) PTM over DSL is up
15:10:23, 23 Apr.
(198999.520000) PTM over DSL is down after 2 minutes uptime
15:10:23, 23 Apr.
(198999.510000) PPPoE is down after 1 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
15:10:18, 23 Apr.
(198994.240000) PPP LCP Send Termination Request [User request]
15:08:49, 23 Apr.
(198905.340000) WAN operating mode is VDSL
15:08:49, 23 Apr.
(198905.340000) Last WAN operating mode was VDSL
15:08:48, 23 Apr.
(198903.920000) PPP IPCP Receive Configuration ACK
15:08:48, 23 Apr.
(198903.870000) PPP IPCP Send Configuration Request
15:08:48, 23 Apr.
(198903.870000) PPP IPCP Receive Configuration NAK
15:08:48, 23 Apr.
(198903.860000) PPP IPCP Send Configuration ACK
15:08:48, 23 Apr.
(198903.860000) PPP IPCP Receive Configuration Request
15:08:48, 23 Apr.
(198903.840000) PPP IPCP Send Configuration Request
15:08:46, 23 Apr.
(198902.580000) PPPoE is up -​ Down Rate=8455000Kbps, Up Rate=1606000Kbps; SNR Margin Down=6.2dB, Up=6.2dB
15:08:46, 23 Apr.
(198902.570000) CHAP authentication successful
Sage
Message 6 of 7
Why not get a decent third party router to go with the openreach modem?
Message 7 of 7
The HH5 is fine with the Openreach modem in front, and I don't need its Wi-Fi as I'm using BT Whole Hone instead. I was just trying to tidy up my desk as the Whole Home disk is sitting on it now as well and originally I got slightly faster speeds with the HH5 on its own
