imjolly
Message 11 of 14
Re: slow broadband
If you get line noise when making/receiving a call then report phone fault to 151
RuralBob
Message 12 of 14
Re: slow broadband
I'm trying to understand my hub stats - so ...
Line attenuation:17.6 / 39.0
Signal attenuation:17.6 / 41.9
If I had a short line with few connections then the two values for Download would be the same as the two values for Upload and then does this mean that I have a problem with my Download line like faulty connections along the line or interference from cross-talk etc?
Noise margin:5.9 / 12.9
Likewise for the noise margin, should they both be the same and close to 6.0?
imjolly
Message 13 of 14
Re: slow broadband
with that high attenuation that just shows you are a long way from the cabinet and will get lower that average speed
noise margin would normally be about 6db but your down is higher because your connection speed is far lower than attainable speed (relatively speaking)
if you have line noise on calls then report phone fault to 151
pippincp
Sage
Message 14 of 14
Re: slow broadband
The difference in attenuation is due to the differences in frequency used for upload & download so they will never be the same.
