leeface
Message 1 of 11
slow speed from 9pm til midnight
im struggling to get speed on my b.t unlimited 1 fibre ,most of the day and night it is a good 38mb but between 9pm and midnight it slows to a crawl of 3mbs any suggestions?
10 REPLIES 10
Message 2 of 11
Re: slow speed from 9pm til midnight
can you post stats from your router  if hh6 then advanced settings then technical log information
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection   can you do this when speed is ok and when you have problem
unusual for congestion to be just 9/12pm as normally starts at peak time 4pm.   are you using wifi or ethernet when problem occurs?
Moderator
Moderator
Message 3 of 11
Hi @leeface I'm sorry your broadband speed is slowing down in the evenings, do you know the name of the exchange that you're connected to? I can check if there are any known congestion problems.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
leeface
Message 4 of 11
Hi Thanks the exchange is
Exchange name:Rugeley Staffordshire  WMRUG
Thankyou
Message 5 of 11
Btspeedtester results?
leeface
Message 6 of 11
I'm using ethernet.thanks
Distinguished Guru
Distinguished Guru
Message 7 of 11
Moderator
Moderator
Message 8 of 11
Hi @leeface and thanks for posting.
I've checked the exchange and there doesn't appear to be any issues listed. Can you post the information as requested by @imjolly ? That might help us get an answer for you.
Cheers
David
Community ModeratorDaveM
Kudos”Kudos”
Moderator
Moderator
Message 9 of 11
Hi @leeface,
How are things with your connection, have you notice an improvement during peak time.
If your still see the slow down, please post back and I'll take a look at this for you.
PaddyB
Community ModeratorPaddyB
Kudos”Kudos”
leeface
Message 10 of 11
Hi,yes the last two nights the speed was fine,hopefully it will be ok,fingers crossed.thankyou everyone who commented for your help.
