Message 1 of 17
slow speed
My infinity has dropped from 36mbs to 25mmbs and was at one time 22mbs  3 engineer visits could not find fault  . 30mbs at test socket but only 25 coming out of hub6 . The hub6 has been replaced and moved next to socket but still only 25mbs . Does my DLM need to be looked at?Capture  checker.PNG
16 REPLIES 16
Moderator
Moderator
Message 2 of 17
Re: slow speed
Hi @coleva,
Thank you for posting. I'm sorry you've seen the speed of your connection drop.
In order to get a better understanding of what's happening with the connection, please can you post your router stats as shown - Broadband - Top Tips to get help on the forum
PaddyB
Message 3 of 17
Re: slow speed
HERE ARE STATS
e
Advanced settings
Technical log
Information
Event log
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ90993924
Firmware version:
SG4B1000B540
Firmware updated:
17-Aug-2019
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
4 Days, 2 Hours 37 Minutes 5 Seconds
Data rate:
7.43 Mbps / 30.99 Mbps
Maximum data rate:
7433 / 30904
Noise margin:
5.7 dB / 4.8 dB
Line attenuation:
24.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
5521 MB Uploaded / 57868 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-X3CP
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-X3CP
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
00:CB:51:B6:4A:9D
Software variant:
Boot loader:
9.2.0
Message 4 of 17
Re: slow speed
BT Hub 6A
Serial number:
+084319+NQ90993924
Firmware version:
SG4B1000B540
Firmware updated:
17-Aug-2019
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
Data rate:
Maximum data rate:
7433 / 30904
Noise margin:
5.7 dB / 4.8 dB
Line attenuation:
24.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Broadband username:
BT Wi-fi:
Active
BTHub6-X3CP
Smart (Channel 1)
BTHub6-X3CP
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
00:CB:51:B6:4A:9D
Software variant:
Boot loader:
9.2.0
Moderator
Moderator
Message 5 of 17
Re: slow speed
Hi @coleva,
Thank you for posting that information. I'm sorry for the delay in posting back, I was out of the office for a few days.
Going by those stats it doesn't look like your line has been banded. Your router is getting 30.99 Mbps, which inside the estimate for your line.
PaddyB
Message 6 of 17
Re: slow speed
Yes I saw that but I am only getting  25 to 26 through the hub when I was getting 36 for at least a year so something must be wrong . The engineers cant find a line fault so it must be in Bt system . Its ironic that they tell me  if I upgrade and pay £3 extra a month I can average 67mbs but they will only guarantee 21mbs
Message 7 of 17
Re: slow speed
Message 8 of 17
Re: slow speed
Upgrading will not make a jot of difference to your speed. The 30M figure is the sync speed of your line which gives a throughput speed of 25/26 after allowing for protocol overheads.
Broadband is not a precise science, speed may well slow down over time as other customers take up service and cause crosstalk problems.
Message 9 of 17
Re: slow speed
But why after a very long time after a serious line fault when a  connection was remade for many customers  I have had a steady speed of 36mbs sometimes 38 mbs  did it drop to  22 then rose to 25 or 26mbs  .the first engineer visit work had to be done at the exchange  the second visit was a recommendation that the hub was at fault so bt sent a new ow and moved it next to socket 3rd visit the engineer replaced the faceplate which improved things slightly . After the first visit the bt monitoring sent an email saying    We've been keeping an eye on it to see if the download speed is 27Mbps, which we promised as part of your Stay Fast Guarantee. Over the last three days your broadband has been slower than what we said you'd get. Sorry about that.                        So as I am only getting 26mbs surely there is something wrong
Sage
Message 10 of 17
Re: slow speed
The Stayfast guarantee covers sync speed. You are syncing at 30.99mb.
