coleva
Message 11 of 17
Re: slow speed
Yes Syncing at 30   only  25 out of hub used to be 36 to 38 out of hub so where has it gone
coleva
Message 12 of 17
Re: slow speed
Can nobody answer the question ?
Message 13 of 17
Re: slow speed
I thought I did in message 8
coleva
Message 14 of 17
Re: slow speed
No  what I want to know is  if I was getting 36 to 38 mbs  out of the hub  why now am I only getting 26mbs out of the hub  . when I recontracted that was the speed I was getting . I didn't buy a 2 litre to get the performance of a 1.3 A 10 mbs drop is quite a bit  and there have been no changes at my end so where have the 10 mbs  gone . if the hub is getting 30 where are the other 4
Message 15 of 17
Re: slow speed
In protocol overheads.
You will never get the same throughput speed as sync speed. Your connection is made up of 7 layers from the physical wire to the application layer each layer has its own overheads and thus slight reduction in speed.
coleva
Message 16 of 17
Re: slow speed
I can only suppose that when I was getting 36 plus  the hub was receiving  40 plus so with the hub nicking 4 it was giving me 36 but as it had been stable  for many many months  it still beggars belief why it drops now
pompey1898
Expert
Message 17 of 17
Re: slow speed
Hi @coleva ,
Have a read about IP Profile etc. here :- https://kitz.co.uk/
This may also help you understand the effects of crosstalk :-
http://www.increasebroadbandspeed.co.uk/2014/vectoring-crosstalk-crisis
