sam2
Message 1 of 4
slow upload speed
Hi our cabinet was recently upgraded for capacity openreach added another fibre cabinet at the side of the pcp since the new one has gone live our upload speed has dropped from 7.5mbps to 3.6 mbps but download has stayed the same. I thought it was just ours so waited a month to see if the speeds would increase. someone i live 300m from has the same issue upload speeds has dropped is there anyway to increse this as the noise margin etc are still the same. ThanksScreenshot 2019-05-09 at 13.44.26.pngScreenshot 2019-05-09 at 13.43.49.png
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: slow upload speed
Hi @sam2 Welcome back and thanks for posting, I'm sorry to see that you've been having problems with your upload speed.  Your Hub stats show a DSL uptime of 19 hours is your connection dropping out on its own or was that a restart of the Hub?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
sam2
Message 3 of 4
Hi Neil0, i rebooted the hub, it was the first time since november just to see if it would improve things. i normally get around 25 days uptime
Moderator
Moderator
Message 4 of 4
@sam2 No worries, thanks for getting back to me. I'll sent you a Private Message with details on how you can get in contact with the mod team and we'll be happy to get this looked into.
Kudos”Kudos”
