mgaj
Message 1 of 13
slower speed than i expected
recently resign up and went for the faster speed. According to bt
We estimate your download speed will be between 63Mb and 80Mb, and your upload speed will be between 19Mb and 20Mb."
In reality went from 38 to around 42/45.
Latested performace check was
      Down      45
      Up          12
      Latency   25.88
Could one of the admin team please look into this and get back to me
12 REPLIES 12
Message 2 of 13
Re: slower speed than i expected
post deleted
Message 3 of 13
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
mgaj
Message 4 of 13
Thanks for looking into this
results from further diags
Hope this is what you need
Thanks again
Message 5 of 13
have you tried connecting to test socket this eliminates all internal wiring that may be affecting your speed can you also please post the help desk page from your home hub as asked for please
mgaj
Message 6 of 13
Tried the test socket - no change
info as requested
Message 7 of 13
The estimated speeds are connection speeds not download speeds. Your firmware is old and not even the last firmware but the firmware before that - there has been 2 updates since your firmware
the attainable speed is not correct and very odd
mgaj
Message 8 of 13
how do i update the firmware
Thanks again for your help so far
Message 9 of 13
It should happen automatically
mgaj
Message 10 of 13
HUb is on 24 hrs but as you say is stilln ot updating - any ideas?
