nokiaman1978
Message 1 of 17
slower speeds
hi wondering if you can help, used to get 70mb plus now lucky to get aboove 60 with speeds ranging from 20 up to the 60 im on infinity 2 and can see the cab from my window im that close, last nigh in the heavy rain my speeds droped to bellow 40 mbits with every speed test, online support is useless as they just follow a script , they did want to book an enigneer but threw in the 150 charge threat if it wasnt a fault outside, has put me off , any help guys, have upgraded to latest mastersocket and connected latest hub without modem
16 REPLIES 16
Message 2 of 17
Re: slower speeds
Is it a BT Home hub 6?
If so can you please show the information on this link?
Smart hub (HH6) connection information- you need to be connected to the home hub to see this info.
nokiaman1978
Message 3 of 17
Re: slower speeds
nokiaman1978
Message 4 of 17
Re: slower speeds
i done speed tests from pc android box and mobile last night , all showing same speeds ,2 wired and mobile wifi
Message 5 of 17
Re: slower speeds
You are connecting at 64Mbs, so you will always get a download speed of less than that.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Could you please post the results from the BT Wholesale speed checker, including the further diagnostics.
BT Wholesale Speedtester
nokiaman1978
Message 6 of 17
Re: slower speeds
nokiaman1978
Message 7 of 17
Re: slower speeds
like i said on original post i used to get 70 plus so something has changed also erratic speed at times esp last night with heavy rain, going with that info is fttp avalible in my area ?
Message 8 of 17
Re: slower speeds
Please edit out your address, as this is a public forum
Message 9 of 17
Re: slower speeds
It could be congestion.
Please see Action to take when download speed are dropping during peak times
Fibre on demand is available if you can afford it.
FTTP on demand Prices for 2018
nokiaman1978
Message 10 of 17
Re: slower speeds
thanks for the help buddy
