nokiaman1978
Message 11 of 17
Re: slower speeds
fttp prices not worth it, damn wish i was back in a virgin media area
nokiaman1978
Message 12 of 17
Re: slower speeds
just a thought when i error check on bt website it does say i have a slow connection to network, what does this mean
Message 13 of 17
Re: slower speeds
I thought not, but you did ask Smiley Wink
If you could follow the instructions regarding congestion, then it may help to establish the cause.
nokiaman1978
Message 14 of 17
speed drops
hi after y stats being looked at and everything ok i was advised to post bt wholesale speed tests, im on infinity 2 and used to get 70 mbits plus but now struggle above 60 with it dropping as low as 25 here is a speed test ive just donelow speed.PNG
Message 15 of 17
Re: speed drops
from the router stats and dslchecker results you are right at bottom of estimated range.  was btspeedtester done with wired connection?
nokiaman1978
Message 16 of 17
Re: slower speeds
Yes wired connection buddy, I can see my green box from window it's only about 100 yards from my house I used to get above 70 so something not right and my speed fluctuates nothing changed my end
nokiaman1978
Message 17 of 17
Re: slower speeds
I will note that there is an engineer at the green box every other day doing work on it nd at least twice a week for some reason
