Message 1 of 35
some help please
could someone have a look at the attached image from ping plotter and let me know whats going on ie why i have 100% constant packet loss on hops 2, 3 and 12, and why I'm having the regular bursts of 100% packet loss. This is happening on wired and wireless connections.
My connection is virtually unusable, and watching internet tv is impossible. I dont lose connection, just webpages fail to load. Many thanks
34 REPLIES 34
Message 2 of 35
Re: some help please
hub stats
Product name:
BT Hub 6A
Serial number:
+084319+NQ61936808
Firmware version:
SG4B10002244
Firmware updated:
27-Apr-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 1 Hours 27 Minutes 31 Seconds
Data rate:
20.00 kbps / 71.34 kbps
Maximum data rate:
20000 / 73776
Noise margin:
12.9 / 6.3
Line attenuation:
14.7
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
1 MB Uploaded / 15 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-CMCW
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-CMCW
5 GHz wireless channel:
Smart (Channel 40)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
Software variant:
Boot loader:
7.33.1
Message 3 of 35
hops 2 3 and 12 are configured not to respond to pings no fault there hop 13 is more your problem
Message 4 of 35
Message 5 of 35
try using bbc.co.uk and se if you have the same problem also google.co.uk
Message 6 of 35
Message 7 of 35
hub lost connection to BT this morning, as it has done since Wednesday when all this started, still getting massive packet loss at 5-10 minute intervals, internet channels on the youview box are unwatchable as it keeps disconnecting and browsing is almost impossible.
Can anyone help please?
Message 8 of 35
@astroman
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 9 of 35
when i reported the problem Thursday, BT sent a phone engineer out as they found a fault on the line, he fixed it, but the internet problem persisted. He ran a quiet test and said everything was fine. If the problem continued I would have to get a broadband engineer out.
I phoned BT yesterday and they ran some tests and said my line and connection are fine, couldn't explain the packet loss and loss of internet though.
Message 10 of 35
as i tried to post the above, it went down completely, couldn't even bring up the smart hub page
