Message 21 of 35
Re: some help please
@astroman wrote:
00:01:51, 01 Jan.
:WAN: SENSING AUTO VDSL
00:01:22, 01 Jan.
ptm0.101:VLAN VLAN_DATA connected
00:01:22, 01 Jan.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:22, 01 Jan.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:22, 01 Jan.
dsl:VDSL link Up: Down Rate=71948Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.30dB
00:00:22, 01 Jan.
____________________________________________________________________________________________________
I can see the disconnections, but the date change would indicate a soft or hard reset. Did you press the reset button?
astroman
Message 22 of 35
just now, packet loss everywhere
astroman
Message 23 of 35
second one i rebooted the hub with the power switch
Message 24 of 35
Please post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
astroman
Message 25 of 35
Product name:
BT Hub 6A
Serial number:
+084319+NQ61936808
Firmware version:
SG4B10002244
Firmware updated:
27-Apr-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 2 Hours 28 Minutes 17 Seconds
Data rate:
20.00 kbps / 71.29 kbps
Maximum data rate:
20000 / 71948
Noise margin:
13.1 / 6.3
Line attenuation:
14.7
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
20 MB Uploaded / 121 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-CMCW
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-CMCW
5 GHz wireless channel:
Smart (Channel 40)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:08:DE:FD
Software variant:
Boot loader:
7.33.1
Message 26 of 35
Its showing an uptime of two and a half hours at the moment, so no disconnects in that time. Everything else is fine, so if you are having problems, it has to be your own computer or how its connected to the home hub.
astroman
Message 27 of 35
it's also happening on my wifes laptop, my phone and my kindle, all those are wireless, my pc is wired so i'm at a complete loss
astroman
Message 28 of 35
i've changed the cable from the hub to the phone socket, I've tried my old hub 5, but the problem is still there
astroman
Message 29 of 35
As this is happening when my WIRED PC is on and off, I can't see it being the problem. I have tried with every device off except my mobile phone and still can't connect via wireless. I have done this individually with each device i have, same result,
My question is then, what since Wednesday evening could be causing 100% packet loss every 5-10 minutes when nothing in the house has changed? I'm baffled
astroman
Message 30 of 35
I have been on online chat with BT which was painfull to say the least with my packet loss lol, the advisor had me doing the usual resets etc, he then said he'd refreshed my line and that would solve the problem, he would call back in an hour to check everything was ok. That should've been at 3.30pm, no call back and my internet is as bad as ever Smiley Frustrated
