astroman
Message 31 of 35
Re: some help please
back on the phone to BT, the chap did loads of tests and reckons its still a fault with the line, another engineer visit on the way
astroman
Message 32 of 35
anyone have any ideas, as this is driving me nuts
Message 33 of 35
Why are so concerned about ping times, as they are not a reliable indication, as responding to ping requests is a low priority task for most sites, so the response could be slow?
The only way to measure transit time and packet loss is to have a specific piece of kit connected to an endpoint, which exchanges packets with a matching piece of kit at your end.
That is a network manager`s task.
astroman
Message 34 of 35
because everytime I get 100% packet loss (red columns) the internet is unusable, the last graph shows 27 times in one hour where I  had 100% packet loss, I'm just trying to find out what could be causing it, the ping times are irrelevant, it's the packet loss i'm concerned about Smiley Happy
astroman
Message 35 of 35
Also had 2 disconnections from the BT Network today
17:50:58, 01 May.
:WAN: SENSING AUTO VDSL
11:04:32, 01 May.
11:03:59, 01 May.
11:03:11, 01 May.
00:01:40, 01 Jan.
00:01:17, 01 Jan.
ptm0.101:VLAN VLAN_DATA connected
00:01:17, 01 Jan.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:17, 01 Jan.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:17, 01 Jan.
dsl:VDSL link Up: Down Rate=73498Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
:WAN: ethernet as LAN
08:13:46, 01 May.
08:09:05, 01 May.
08:08:35, 01 May.
08:08:27, 01 May.
08:07:41, 01 May.
05:01:47, 01 May.
05:01:41, 01 May.
02:14:36, 01 May.
23:17:30, 30 Apr.
00:01:31, 01 Jan.
00:01:10, 01 Jan.
00:01:10, 01 Jan.
00:01:10, 01 Jan.
00:01:10, 01 Jan.
dsl:VDSL link Up: Down Rate=73880Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:00:25, 01 Jan.
