Message 11 of 35
Re: some help please
Network uptime:
0 Days, 0 Hours 4 Minutes
System uptime:
0 Days, 18 Hours 26 Minutes
Message 12 of 35
Can you run the quiet line test now please?
Message 13 of 35
@astroman wrote:
as i tried to post the above, it went down completely, couldn't even bring up the smart hub page
Was that using a direct Ethernet cable from the home hub to your computer?
Message 14 of 35
quiet line test ok, and yes the pc was connected via ethernet
Message 15 of 35
here's the last 3 hour pingplotter graph, the 2 thick red lines are the 2 times I completely lost connection
Message 16 of 35
just had two complete losses of internet, this is the log from the hub
13:08:09, 30 Apr.
ppp1:DNS name resolution failure (207.57.239.216.in-addr.arpa)
13:08:09, 30 Apr.
ppp1:DNS name resolution failure (185.126.99.195.in-addr.arpa)
13:07:39, 30 Apr.
ppp1:DNS name resolution failure (168.31.72.194.in-addr.arpa)
13:07:24, 30 Apr.
ppp1:DNS name resolution failure (184.187.55.31.in-addr.arpa)
13:06:55, 30 Apr.
ppp1:DNS name resolution failure (18.46.239.216.in-addr.arpa)
13:06:54, 30 Apr.
ppp1:DNS name resolution failure (220.255.85.209.in-addr.arpa)
13:06:54, 30 Apr.
ppp1:DNS name resolution failure (207.193.121.213.in-addr.arpa)
13:05:01, 30 Apr.
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:e168:5500:8c4b:2fe9:3d0d:46b9 is set inactive
13:04:46, 30 Apr.
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:e168:5500:5d65:fbd1:b5e3:d209 is set inactive
13:04:14, 30 Apr.
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:e168:5500:5d65:fbd1:b5e3:d209 is set active
13:03:46, 30 Apr.
BR_LAN:LAN Neighbor Discovery : Host fe80::f5b8:9004:688b:96c7 is set inactive
13:03:34, 30 Apr.
13:03:08, 30 Apr.
BR_LAN:LAN Neighbor Discovery : Host 2a00:23c4:e168:5500:8c4b:2fe9:3d0d:46b9 is set active
13:03:05, 30 Apr.
BR_LAN:LAN Neighbor Discovery : Host fe80::f5b8:9004:688b:96c7 is set active
13:03:01, 30 Apr.
13:02:35, 30 Apr.
13:02:27, 30 Apr.
13:02:15, 30 Apr.
13:02:01, 30 Apr.
ppp1:DNS name resolution failure (_xmpp-client._tcp.message-live.youview.tv)
13:02:01, 30 Apr.
13:01:43, 30 Apr.
13:01:30, 30 Apr.
13:01:05, 30 Apr.
13:00:48, 30 Apr.
13:00:15, 30 Apr.
13:00:08, 30 Apr.
12:59:43, 30 Apr.
12:59:39, 30 Apr.
wl0:Device <1C:E6:2B:D1:76:96> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV5G])
Message 17 of 35
no idea how the smileys got in there ffs
Message 18 of 35
They look like the LAN logs not the WAN logs. You need to select the WAN logs only.
The WAN logs would show any line disconnects.
Message 19 of 35
last 5 minutes, the internet unusable, taken ages to just post thiswww.google.co.uk3.jpg
Message 20 of 35
00:01:51, 01 Jan.
:WAN: SENSING AUTO VDSL
00:01:22, 01 Jan.
ptm0.101:VLAN VLAN_DATA connected
00:01:22, 01 Jan.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:22, 01 Jan.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:22, 01 Jan.
dsl:VDSL link Up: Down Rate=71948Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.30dB
00:00:22, 01 Jan.
:WAN: ethernet as LAN
10:56:04, 30 Apr.
10:54:52, 30 Apr.
10:20:57, 30 Apr.
05:30:25, 30 Apr.
05:15:54, 30 Apr.
05:15:06, 30 Apr.
03:22:42, 30 Apr.
19:16:50, 29 Apr.
17:56:25, 29 Apr.
17:35:21, 29 Apr.
00:01:43, 01 Jan.
00:01:20, 01 Jan.
00:01:20, 01 Jan.
00:01:20, 01 Jan.
00:01:20, 01 Jan.
dsl:VDSL link Up: Down Rate=73776Kbps, Up Rate=20000Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:00:22, 01 Jan.
16:34:25, 29 Apr.
dsl:VDSL Link Down: duration was 7650 seconds
16:34:24, 29 Apr.
:VLAN VLAN_DATA disconnected
