picktech
Message 1 of 44
speed dropping wifi and wired
hi all new on here so thought i would give it a go,
i have had bt infinity installed,
it as been in just over a month now and i have had at the best about 5 days with out a problem, i have had to phone up support our nice friends in India who read from a computer, so we can go through the regular diagnostics and get now where,
my problem is the dropping of wired and wifi and low speeds i have done all what i can think of ie, master socket line test (quiet test) no noise on line, turn of smart setup, channel changing and all to no avail i have the latest firmware update for my BTHub5a dual wifi not synced this happens at different times of the day done speed tests sometimes no server and did not complete, at my wits end, thinking of canceling as they are not providing a service i signed up for, sent email to watchdog this morning and i am making a complaining to ofcom,  regards picktech thank in advance for any help
43 REPLIES 43
Distinguished Guru
Message 2 of 44
Re: speed dropping wifi and wired
Can you post your helpdesk data from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254 or http://bthomehub.home or http://bthub.home
Please miss out any data you don't want to post
If not, I'll try again 🙂
picktech
Message 3 of 44
what info do you need  to post
Message 4 of 44
The stats from 1-12 is enough.
Log onto the Homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
Distinguished Guru
Message 5 of 44
1-12 misses out the wireless information unfortunately and as the problem is wireless it would be good to see the settings
picktech
Message 6 of 44
1. Product name:	BT Home Hub
2. Serial number:	+068543+NQ44909964
3. Firmware version:	Software version 4.7.5.1.83.8.204 (Type A) Last updated 19/02/15
4. Board version:	BT Hub 5A
5. DSL uptime:	1 days, 04:14:37
6. Data rate:	9995 / 39993
7. Maximum data rate:	19455 / 67944
8. Noise margin:	12.6 / 14.3
9. Line attenuation:	18.4 / 17.4
10. Signal attenuation:	18.3 / 17.5
11. Data sent/received:	338.3 MB / 2.1 GB
12. Broadband username:	bthomehub@btbroadband.com
 got some speed yesterday for a while, did a speed test this morning and got 7mb down on the bt web site, i have been informed by our friends in india to do changes on settings ie changing wifi b/g up to 54  mb/s if this helps
Distinguished Guru
Message 7 of 44
You're getting full speed on Infinity 1
Distinguished Guru
Message 8 of 44
Which exchange are you connected to?
picktech
Message 9 of 44
cudworth south yorkshire
Distinguished Guru
Message 10 of 44
You can try fixing wireless problems by turning off Smart Wireless and splitting the 2.4 GHz and 5 GHz bands. To do this:
1. Go into your advanced settings on the HH5 and select the wireless tab.
2. Then select the 5GHz tab and select NO to "Sync with 2.4 GHz:".
3. Then choose a new SSID by adding "5" to the existing one, so you can tell the difference between 2.4GHz and 5GHz bands.
4. While you're there change "Channel selection:" from "Smart wireless" to the current channel.
5. Then press the "Apply" button.
6. Then choose the 2.4GHz tab and change "Channel selection:" from "Smart wireless" to the current channel on 2.4GHz.
7. Then press the "Apply" button again.
Now on your devices you can select which SSID (which band, 2.4GHz or 5GHz) to connect to.
