picktech
Message 11 of 44
Re: speed dropping wifi and wired
sorry just lost connection again, i have already tried this to no avail,
did not have this problem with normal broadband, its been one big headache as i am learning as i go so thank you for helping
Message 12 of 44
@ray_dorset wrote:
1-12 misses out the wireless information unfortunately and as the problem is wireless it would be good to see the settings
When I read the post header it says  "speed dropping wifi and wired".  This would indicate to me that there is probably a connection problem not a wireless problem but if you need the part of the stats that give the wireless information perhaps the OP should post them for you.
Distinguished Guru
Message 13 of 44
What connection did you lose? I mean, you must be connected to a web site or something?
If not, I'll try again 🙂
picktech
Message 14 of 44
it happens with both wired and wifi, what is the OP, it is intermittent
picktech
Message 15 of 44
13. BT Wi-fi:	Yes
14. 2.4 GHz Wireless network/SSID:	BTHub5-T787
15. 2.4 GHz Wireless connections:	Enabled (802.11 b/g (up to 54 Mb/s))
16. 2.4 GHz Wireless security:	WPA2
17. 2.4 GHz Wireless channel:	12
18. 5 GHz Wireless network/SSID:	BTHub5-T787
19. 5 GHz Wireless connections:	Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:	WPA2
21. 5 GHz Wireless channel:	Automatic (Smart Wireless)
 hope this helps
Distinguished Guru
Message 16 of 44
To be honest, it doesn't look like you've turned off smart wireless, or split the networks as I suggested 😞
Distinguished Guru
Message 17 of 44
Is your wired connection using power line adapters?
picktech
Message 18 of 44
i see what u see but i have change them back, and turned smart back on, thanks for help
picktech
Message 19 of 44
no not used them, just been reading that others are having the same problem, and it as started like mine after or around the same time as the update on the 22/01/2015,
Distinguished Guru
Message 20 of 44
Is your wired connection actually using Homeplugs as they can be a problem causing interference?
