picktech
Message 21 of 44
Re: speed dropping wifi and wired
no ray, i have tried putting router in middle of home, it is plugged into the master socket, my laptop is wired and wifi to router, have tried it with and without wifi and visor verso,
craigst
Message 22 of 44
could be faulty home hub ? do you have another vdsl router to try and test ?
picktech
Message 23 of 44
been on to bt and they have done tests and said they are sending me a new hub, thanks for all your help will be learning all about wifi and hubs from now on thasnks once again
regards picktech
picktech
Message 24 of 44
well here we go again, so to bring you all up to speed(pardon the pun) my new bt hub5a arrived a day late, so i installed it as i did the last and to the instructions, all was well for a day and half then hay presto the drop out starts again was waiting for our friends from india to call today as they said they would, but alas no call, i have looked on my bt and it is showing that there is still an open fault, anyway here is what i have done so far, changed the wireless ssid and gave them different names, turned of smart setup, and now on channel 11, that is the wifi side, on the cable side just have a lan cable to the hub and that seen to work a little better, when it is up and running i get around the speed they said i would, this is starting to drive my round the bend now, here is my help desk
1. Product name:	BT Home Hub
2. Serial number:	+068343+NQ33690493
3. Firmware version:	Software version 4.7.5.1.83.8.204 (Type A) Last updated 18/01/15
4. Board version:	BT Hub 5A
5. DSL uptime:	0 days, 03:37:54
6. Data rate:	9999 / 40000
7. Maximum data rate:	17308 / 69434
8. Noise margin:	9.2 / 10.8
9. Line attenuation:	18.6 / 17.3
10. Signal attenuation:	18.5 / 17.3
11. Data sent/received:	566.8 MB / 3.8 GB
 at this moment in time it is fine so any help would be  appreciated
kind regards pickteck
Distinguished Guru
Message 25 of 44
Do the lights change colour on the HH5A ?
If not, I'll try again 🙂
picktech
Message 26 of 44
no ray sorry just got back on only when i reset the hub
Distinguished Guru
Message 27 of 44
So it's not the hub dropping out, just the connection to the PC?
picktech
Message 28 of 44
i have had the help desk tool on, and that goes through its connection test and says the hub is having a problem connecting to the internet, then a while later i gat i signal again just wondering if it could be the DSL cable from the hub to the filter, i am plugged in to the master socket behind the front plate
Distinguished Guru
Message 29 of 44
I think that would cause the lights to change colour. I would suspect the wireless connection and/or the ethernet cables and/or the PC
Distinguished Guru
Message 30 of 44
The event log on the HH5 may give some clues.
