redstar
Message 1 of 2
speed going down
installed last year may 2012 my line estimate was 51.1-13.2 ,now slowly going down after bt keeps resetting my system also why is qos quality of service set ?
my line one week after install  Download speedachieved during the test was - 53 Mbps For your connection, the acceptable range of speedsis 12 Mbps-57.39 Mbps . Additional Information: IP Profile for your line is - 57.39 Mbps 2. Upstream Test: -provides background information. Upload Speed 13.71 Mbps
 08:20:30,31 May.CWMP:Set Parameter by TR069 Success.
08:20:28,31 May. CWMP:session completed successfully
08:20:27,31 May. CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, 6 CONNECTION REQUEST 08:20:27,31 May. HTTP authentication success from 64.186.182.xxx
08:20:27,31 May. HTTP authentication Fail from 64.186.182.xxx
08:20:26,31 May. HTTP Recv authorization success respond from:66.193.112.xx
08:20:23,31 May. HTTP Recv authorization failed respond from:66.193.112.xx
08:20:23,31 May. CWMP:session completed successfully
08:20:22,31 May. CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, 4 VALUE CHANGE, M Reboot, 1 BOOT
08:20:20,31 May. SAAF:Initialize TR69 Client Interface success.
08:20:20,31 May. Client associated: IP 192.168.1.71, MAC 20:4E:7F:4F:F1:3D, host sky-20-4E-7F-4F-F1-3D, Link Rate 48.0 Mbps 08:20:17,31 May. LAN4 up
08:20:15,31 May. LAN3 up 08:20:15,31 May. WAN Auto-sensing detected port ETH
08:20:15,31 May. WAN Auto-sensing last connection port: ETH
08:20:13,31 May. NTP synchronization success!
08:20:13,31 May. NTP synchronization start.
00:01:10,01 Jan. WAN connection WAN4_TR069_INTERNET_R_ETH1 connected.
00:01:09,01 Jan. QoS Rate cap set to 21.9Mbs
00:00:54,01 Jan. PPP IPCP Receive Configuration ACKm
00:00:54,01 Jan. PPP IPCP Send Configuration Request
00:00:54,01 Jan. PPP IPCP Receive Configuration Reject
00:00:54,01 Jan. PPP IPCP Receive Configuration NAK
00:00:54,01 Jan. PPP IPCP Send Configuration ACK
00:00:54,01 Jan. PPP IPCP Receive Configuration Request
00:00:54,01 Jan. PPP CHAP receive success: authentication ok
00:00:54,01 Jan. PPP CHAP Receive Challenge
00:00:54,01 Jan. PPP LCP Receive Configuration ACK
00:00:54,01 Jan. PPP LCP Send Configuration Request
00:00:54,01 Jan. PPP LCP Receive Configuration Reject
00:00:54,01 Jan. PPP LCP Send Configuration ACK
00:00:54,01 Jan. PPP LCP Receive Configuration Request
00:00:51,01 Jan. WAN connection WAN2_INTERNET_B_ETH2 connected.
00:00:51,01 Jan. Gigabit Ethernet Link Up, Rate: 100Mbps
00:00:51,01 Jan. System up, firmware version:V100R001C01B036SP03_L_B
00:00:42,01 Jan. NTP synchronization fail!
00:00:42,01 Jan. NTP synchronization start.
00:00:26,01 Jan. WiFi Up
00:00:26,01 Jan. WiFi manually selected 20M channel 11
00:00:26,01 Jan. WiFi Down
08:18:39,31 May. Reboot from the WAN side.
08:18:38,31 May. CWMP:Reboot Success
08:18:38,31 May. CWMP:session completed successfully
08:18:37,31 May. CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, 6 CONNECTION REQUEST
After this it went from 38/13  to this
1. Best Effort Test: -provides background information. Download Speed 32.92 Mbps 0 Mbps 33.92 Mbps Max Achievable Speed Download speedachieved during the test was - 32.92 Mbps For your connection, the acceptable range of speedsis 16 Mbps-33.92 Mbps . Additional Information: IP Profile for your line is - 33.92 Mbps 2.
Upstream Test: -provides background information. Upload Speed 11.89 Mbps 0 Mbps 20 Mbps Max Achievable Speed Upload speed achieved during the test was - 11.89Mbps Additional Information: Upstream Rate IP profile on your line is - 20 Mbps
1 REPLY 1
SaiBork
Message 2 of 2
Re: speed going down
That's what I'm having too and am now down to a 10 Mbps line with 3.5 Mbps upload..
http://community.bt.com/t5/BT-Infinity/Any-way-to-reset-IP-profile/td-p/877716
So I think soon I might need to get BT to break contract as this just sucks. I can get faster and a load cheaper ADSL which doesn't keep dropping my speeds.
