scotta1980
Message 1 of 6
speed halved since sign up
when i signd up to bt in december i was told i i could get around 63.3-80mbps the speed were good at start was was getting between 56-60mbps but my speed has gone down rapidly infinity is new in my area the openreach van is alwas at the cabinet this is the dsl checker i done no long after i got infinity 2
but i have done one today and this is what it is showing
how can i downgrade to infinity 1 because i am clearly not getting infinity 2 speeds on my line i  have done a check on the bt website to see what broadband i can get on my line it is now saying i can only get fiber broadband  with speeds of 33-46mbps but when i signd up it sayed superfast fiber broadband between 63-80mbps
can any mod help with this
this is a recent speed test on wired line
5 REPLIES 5
Distinguished Guru
Message 2 of 6
Re: speed halved in to since sign up
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
If not, I'll try again 🙂
scotta1980
Message 3 of 6
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name: BT Home Hub
2. Serial number: +068543+NQ43109122
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. VDSL uptime: 0 days, 00:07:33
6. Data rate: 7714 / 47229
7. Maximum data rate: 10155 / 61241
8. Noise margin: 5.8 / 6.0
9. Line attenuation: 0.0 / 22.1
10. Signal attenuation: 0.0 / 21.0
11. Data sent/received: 9.3 MB / 63.7 MB
12. Broadband username: bthomehub@btbroadband.com
Distinguished Guru
Message 4 of 6
It looks like there is noise on your line which is reducing your data rate to 47 megs from your max of 61 megs. If you downgrade to Infinity 1 you would lose a further 10 megs.
scotta1980
Message 5 of 6
just spoke to bt and they said i should be getting minimum of 63mbps on my line recording to their computers i have done a quiet line test and sounds all clear they said to give it 48 hours but i have been told this rubbish before just their way of getting you off the phone
Distinguished Guru
Message 6 of 6
This sort of noise will be inaudible as it's at radio frequency. The QLT can indicate a line fault if you can hear crackling from a bad connection.
