SGM336
Message 1 of 11
speed
hello . this is my first time posting to these forums but im hoping someone can shed some light on a problem i have.
I am on BT Unlimted Infinity, up 52mb download and up to 9.5mb upload. I was advised by a BT support team member that i should achieve up 37mb however im getting only 22.01
here is a technical log of speed line attenuation noise etc:
Product name:
BT Hub 6A
Serial number:
+084319+NQ73976489
Firmware version:
SG4B1000B522
Firmware updated:
11-Mar-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 4 Hours 34 Minutes 36 Seconds
Data rate:
1.22 Mbps / 22.01 Mbps
Maximum data rate:
1217 / 22609
Noise margin:
6.5 dB / 6.3 dB
Line attenuation:
30.2 dB
Signal attenuation:
Can anyone tell my why i cant achieve the 37mb? i have tried rebooting and resetting the hub (Smart hub 6) and still nothing, or at least help me understand what going on lol thx
10 REPLIES 10
SGM336
Message 2 of 11
Speed
Product name:
BT Hub 6A
Serial number:
+084319+NQ73976489
Firmware version:
SG4B1000B522
Firmware updated:
11-Mar-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
Data rate:
Maximum data rate:
1217 / 22609
Noise margin:
6.5 dB / 6.3 dB
Line attenuation:
30.2 dB
Signal attenuation:
imjolly
Message 3 of 11
Re: Speed
Can you enter your phone number and post results remember delete number https://www.btwholesale.com/includes/adsl/adsl.htm
have you tried connecting to test socket with a filter to eliminate internal wiring
try quiet line test dial 17070 option 2 should be quiet and best with corded phone
SGM336
Message 4 of 11
Re: Speed
hi there yes i tried the 17070 option 2 and heard nothing except a very faint hiss.  I have tried the test socket no differance.
As requested here is the results from the webpage you suggested:
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)26.218.11.71.115.8Available----
VDSL Range B (Impacted)20.2101.50.87.9Available----
WBC ADSL 2+Up to 11--6.5 to 15Available----
WBC ADSL 2+ Annex MUp to 11Up to 16.5 to 15Available----
ADSL MaxUp to 6--5 to 8Available----
Fixed Rate2 ----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date28-02-2018
SGM336
Message 5 of 11
Re: Speed
BT say i should reach 37 but going by this it dont look like its going to do it in which case i aint going to pay £49.99 per month for 20mb >.<
SGM336
Message 6 of 11
Re: Speed
Just did a TAP 3 test using speedtest@speedtest_domain as my username in the hub login page as suggest on different forum and ran a test, this is what I got: 1. Best Effort Test: -provides background information. Download Speed 0 Mbps 0 Mbps 33.87 Mbps Max Achievable Speed Download speedachieved during the test was - 0 Mbps For your connection, the acceptable range of speedsis 20 Mbps-33.87 Mbps . Additional Information: IP Profile for your line is - 33.87 Mbps 2. Upstream Test: -provides background information. Upload Speed 0.86 Mbps 0 Mbps 2 Mbps Max Achievable Speed Upload speed achieved during the test was - 0.86Mbps Additional Information: Upstream Rate IP profile on your line is - 2 Mbps This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault. If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results sure if this has any relevance or helps at all but this shows my ip profile to be 33.87. yet when I switch back to my default username bthomehub@btbroadband.com and run the normal test via speedtest.btwholesale.com I get an ip profile of 21.57mbps for down load and an upload profile of 10mbps..what the heck is going on?
pippincp
Message 7 of 11
Re: speed
Can you connect to the test socket and repost the stats please?
Also put you phone number in HERE and post a screenshot of the result. Remove your phone# before posting.
SGM336
Message 8 of 11
Re: speed
test socket made no differance. the link you have given has been done already and results are in previous post and removing my phone would make no differance either. I spoke with BT today and they say that in my area 26mb is as fast i can go, so paying £50 per month for unlimited infinity up 52mb download and getting 26mb is fine as far as BT is concerned. They stare the the promised speed is 18 anything over that is fine....go figure lol. Many thanks to all who replied but it looks like i have to put up with it 🙂
imjolly
Message 9 of 11
Re: speed
from the checker results it does look like your connection is within estimate.  you may find you get a bit faster if/when G.INP is activated
SGM336
Message 10 of 11
Re: speed
and that asks the question when will G.INP be activated is there a way to check for this? what is G.inp?
