michaelgreen45435
Message 1 of 31
speedtest shows my wired internet speed is 6.88bps. is this normal
Download Mbps
6.88
Upload Mbps
4.40
Is this normal ? My internet feels awfully slow at times
30 REPLIES 30
Sage
Sage
Message 2 of 31
Re: speedtest shows my wired internet speed is 6.88bps. is this normal
Could you post the connection stats from the hub.
HH6 Advanced settings/technical log/information.
HH5 Troubleshooting/helpdesk.
Message 3 of 31
can you also enter your phone number and post results  remember delete number   https://www.dslchecker.bt.com/adsl/adslchecker.welcome
michaelgreen45435
Message 4 of 31
michaelgreen45435
Message 5 of 31
Product name:
BT Hub 6A
Serial number:
+084317+NQ80228158
Firmware version:
SG4B1000E016
Firmware updated:
10-May-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 13 Hours 56 Minutes 19 Seconds
Data rate:
5.00 Mbps / 7.89 Mbps
Maximum data rate:
8256 / 51152
Noise margin:
6.7 dB / 31.6 dB
Line attenuation:
19.3 dB
Signal attenuation:
0 dB / 19.3 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
1281 MB Uploaded / 25226 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
mike
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
mike
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
3C:17:10:97:38:2D
Software variant:
Boot loader:
9.2.0
Message 6 of 31
Do you have dial tone? Looks like a possible disconnection of one wire, broadband will work very slowly but you won't get dial tone.
Message 7 of 31
Have you tried a factory reset of hub by holding recessed button on back for 20/30secs until lights flash
are you using the test socket. With a filter as that should be best connection
cheack you have a dial tone then dial 17070 option 2 should be silent and best with corded phone
michaelgreen45435
Message 8 of 31
okay
17070 option 2 sounded silent
my internet wire is plugged into this
Message 9 of 31
Unclip the front faceplate and connect your hub to the test socket behind using a new filter and repost hub stats. That will eliminate the master socket and any internal wiring.
michaelgreen45435
Message 10 of 31
is it just an internet filter off ebay ?
and then I put my itnernet cable into that, then the filter into the previously used socket ?
