PikAlien
Message 1 of 4
superfast broadband speed Guarantee
Can anyone help with advising me as to who to contact with regard to guaranteed speed on my 50Mb package.
I have been told it should be minimum 37Mb download but has never been more than 14Mb average.
3 engineers have visited in the last month and each has reported that as the fibre Cab. is just over 1 Km from my house there is no way I will receive 37Mb download.  It is then on copper to another cab  and then on to my premises.
The second cab it goes through also has a fibre cable feed to it and is 0.6 Km from me.
They have all reported back on fault report that a cease and reprovide of my line onto the closer cab will give me the quoted  37Mb download speed.
I can only assume that package was sold thinking I was on the closer cab fibre. However I am unable to get anyone on the numerous help desks contacted  to take this on board and everyone is still assuming it is a fault even though I have constantly informed them that a cease and reprovide will solve the problem.
I am now being awaiting a Technical Help Desk in India to look into it and contact me later in the week when all I need is someone to make the decision to switch me to different cab or tell a reason why they cannot. I am at my wits end over this
3 REPLIES 3
imjolly
Message 2 of 4
Re: superfast broadband speed Guarantee
Can you post hub stats advanced settings then technical log information
enter phone number and post results. Delete number.  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
There are many posts on the forum about changing cab to improve your connection speed and answer is the same. Openreach will not change your cab just to increase your broadband connection speed
PikAlien
Message 3 of 4
Even if the package you are paying for has a speed guarentee  of more than double you actually getting and they claim will do everthing possible to acheive
How fast will my broadband be?
We estimate your:
  • download speed will be between 42Mbps and 50Mbps
  • upload speed will be between 8Mbps and 9Mbps.
Your Stay Fast GuaranteeYour Stay Fast download speed is 37Mbps.
Your minimum download speed
If your download speed isn't at least 37 Mbps, get in touch and we'll do our best to fix it.
Strangely I would think "We'll do our best to fix it" actually means we'll do our best to fix it
imjolly
Message 4 of 4
'Download speed' in the correspondence from BT is actually connection speed - it is explained in T&C
dslchecker results will show connection speed range and stats will help forum members help you
