planetf1
Expert
Message 1 of 2
t.co resolution failures from BT primary DNS
Resolution of t.co has been intermittently failing from the primary BT DNS server 81.139.57.100 - DNS error is "server failed"
Secondary DNS server 81.139.56.100 is responding correctly.
However HH users can't so easily override (except on individual clients).
Any outlook on a fix?
Is this reported as a known issue?
1 REPLY 1
planetf1
Expert
Message 2 of 2
Re: t.co resolution failures from BT primary DNS
Note that in seeing what another friend on BT is seeing, that this is quite intermittent. one moment it works... then next it doesn't.... 😉
