steve1k
Message 1 of 3
test results
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: test results
@steve1k you get that info form the BT Wholesale availability checker on this link.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Guru
Guru
Message 3 of 3
Re: test results
It's at http://www.btwholesale.com/adslchecker
Edit,@NeilO - snap 😄
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
