jonew
Message 1 of 2
u o trace results and meanings
Hi. Ive been having laggy ps3 gameplay recently and decided to get some help from ea.com..
They've asked me to do a uotrace which I have now done but I have no idea what the results mean.
Anything above 100ms can cause lag they say n I've noticed at least 4 servers are above 100ms..
Ip 4.69.137.54 121ms
Ip 4.69.134.158 114ms
Ip 4.69.149.197 137ms
Ip 159.153.224.2 116ms
Are these relevant?
All the rest are under 100ms
1 REPLY 1
TheTvMan
Message 2 of 2
Re: u o trace results and meanings
The first 3 are addresses is the US and it appears and the last is as server owned by EA themselves. Doubt that helps but I don't really know what orther info you are after. I'd just to the trace and send the full results to whomever i shelping you.
