Garthy
Message 1 of 14
ultrafast equipment
i'm thinking about the ultrafast fttp but what is entailerd for installation. and what hardware bdo they bring?
13 REPLIES 13
Starwire2000
Recognised Expert
Message 2 of 14
Re: ultrafast equipment
Obviously they bring an FTTP Cable to your house.
Depending on whether it’s a Legacy (Blown) Fibre or CBT Network then they may have to install a CSP on the outside of your house. Some Engineers still Install CSP’s on CBT Fibre.
They then fit a ONT inside your house. It’s quite big(ish) but you can’t have FTTP without it.
Your Router then plugs into the ONT.
Garthy
Message 3 of 14
how big is the ONT? Can i use my own router?
imjolly
Message 4 of 14
sorry but I assume ultrafast is option shown here  https://www.btwholesale.com/includes/adsl/main.html
licquorice
Message 5 of 14
252.4mm x 215mm x 39.5mm enclosure containing ONT and BBU and yes as long as it has a WAN port
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=2ahUKEwjp_I-544HgAhUnSxUIHTgjC...
Garthy
Message 6 of 14
it says wbc fttp 1000. will my cable frompole tp house change?
Garthy
Message 7 of 14
thank you. i'll check for size
licquorice
Message 8 of 14
Yes, your current cable will be copper
Starwire2000
Recognised Expert
Message 9 of 14
If it’s Legacy (Blown) Fibre then they’ll put up Fibre Tuping to the house.
If it’s CBT Fibre then the cable does carry a Copper Pair in it.
Depending on the Engineer and the location you want the ONT they may just leave the existing copper cable up and put the Hybrid Fibre/Copper Cable up as well.
Garthy
Message 10 of 14
how do i know which it is?
