Starwire2000
Recognised Expert
Message 11 of 14
Re: ultrafast equipment
On the pole outside is there what looks like a egg shell box that’s been painted black at the top?
If so it’s CBT Fibre.
If there’s a Manifold, a black oval shaped thing then it’s Blown Fibre.
Garthy
Message 12 of 14
it has an eggbox on top of the pole. so if it has copper wires do they do phone? so no bbu?
what about where cable comes into the house is there a box on the outside wall. at the moment my cable is hidden behind guttering and only small hole in wall
Starwire2000
Recognised Expert
Message 13 of 14
Depends on the Engineer.
With CBT you can use a Connectorised End but a lot of Engineers don’t use them as they have high failure rates.
Instead it’s better and more reliable to fit a Customer Splice Point on the outside of your house and use an EZ Bend Fibre Cable.
The Connectorised Ends are **bleep**e and the Company knows they are as they are going to replace them soon with a new type of premade connector End.
Garthy
Message 14 of 14
thank youi all for help. i will try and work a plan out.
